1. bjyorn's Avatar
    Hello,
    Been using my S4 for about two weeks and noticed an annoying issue when using my car charger + 1 stock Samsung included micro usb cable & one cheap cable I got off amazon. While plugged into my car charger with GPS on and using the stock cable, I noticed that my battery actually charges and usually at the end of a trip I'm left with a higher charge % than when I started. However, when I use the cheap generic cable the charge % drops slowly over the course of the trip. Of course I was plugged into the non-apple side of the charger (non-data), all other variables were kept the same when I tested between the two cables.
    For reference, here are amazon links to my car charger & the cheap cable:
    Amazon.com: PowerGen Dual USB 3.1A 15w High Output Car Charger - BLACK: Cell Phones & Accessories
    Amazon.com: Samsung OEM Micro USB Data Charging Cable 5ft for the Samsung Galaxy S3: Cell Phones & Accessories
    Should I be using a different cable to replicate the charging performance I am getting with the official Samsung cable? Any advice on brands, spec's?
    Thanks!
    06-02-2013 05:22 PM
  2. friedtators's Avatar
    Yes the charger is more important than ever.
    satannik likes this.
    06-02-2013 05:54 PM
  1. Galaxy S4 AT&T Without a Service Plan Question
    By DropZite in forum Samsung Galaxy S4
    Last Post: 05-02-2013, 12:35 AM
  2. Galaxy S4 AT&T Without a Service Plan Question
    By DropZite in forum AT&T Samsung Galaxy S4
  3. Charging Question
    By iJason#WN in forum Motorola Droid X
    Last Post: 08-18-2010, 11:42 PM
  4. Charging question
    By eric.atx in forum HTC EVO 4G
    Last Post: 06-14-2010, 07:03 PM
  5. Battery Charging question
    By grifforama in forum HTC Hero
    Last Post: 12-15-2009, 08:55 AM
