1. raziel's Avatar
    I'm not sure if I'm the only one with this problem but has anyone experienced any lagging with SwiftKey? I am using the Nova launcher and the UI slows to a crawl when I flip screens with Swift Key being the default keyboard. If I switch to the Samsung keyboard or Swype, the lag goes away. Even when using the keyboard itself, there is an occasional stutter (doesn't happen all the time). I of course have the latest version of Swift Key and have this problem on both TouchWiz and Nova launchers, stock and custom ROMS. I also don't see this problem on my HTC One.
    Thanks!
    06-03-2013 04:35 PM
  2. Boofz's Avatar
    I get the same type of studder when I'm using something that requires the keyboard... there is a split second hesitation when the keyboard comes up. Kinda annoying.
    06-03-2013 06:09 PM
  3. skyjjc's Avatar
    No noticeable lag here. Using SwiftKey and stock launcher
    Sent from my SCH-I545 using Tapatalk 2
    06-03-2013 06:16 PM
  4. Dural's Avatar
    None, and I'm using Swiftkey with Nova. It's likely another app (or setting) at fault.
    06-03-2013 06:19 PM
  5. orion575's Avatar
    I'm using Swiftkey and Swype with a stock TW and I don't have any lag
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
    06-03-2013 11:06 PM
  6. speed13's Avatar
    I'm using swift key and I earlier posted lag while I typing little delay
    Sent from my Galaxy S4 White - using Tapatalk
    06-04-2013 01:13 AM
  7. speed13's Avatar
    Please try to disable smart rotation and see if issues still there?
    06-04-2013 01:19 AM
  8. atlantar6's Avatar
    SwiftKey and stock launcher works fine for me.
    06-04-2013 01:42 AM
  9. raziel's Avatar
    I uninstalled swift key, installed kii my lag issues have been resolved!
    06-04-2013 02:27 AM
  10. cgardnervt's Avatar
    I keep hearing about this Kii keyboard! I just may have to try it out. I have Swiftkey on my HTC One and no lag. How do you like Kii's key lay out?
    06-04-2013 08:27 AM
  11. weblou's Avatar
    I just gave kii a test it does feel faster then swift and swipe
    Sent from my SGH-I337M using Tapatalk 4 Beta
    06-04-2013 09:40 AM
  12. paintdrinkingpete's Avatar
    Swiftkey with Nova...and I don't notice any lag at all...maybe there's a 3rd factor involved somewhere?
    06-04-2013 09:48 AM
  13. Zod1010's Avatar
    Where can I find this? Thanks.
    06-04-2013 09:53 AM
  14. paintdrinkingpete's Avatar
    I'm not sure what "Smart Rotation" is either...however I will add that keep auto-rotate and smart-scroll both turned off. As mentioned above, I do NOT have noticeable lag on my S4 with Swiftkey and Nova launcher.
    06-04-2013 09:58 AM
  15. speed13's Avatar
    My device and smart screen
    06-04-2013 10:02 AM
  16. Zod1010's Avatar
    Thank you.
    06-04-2013 11:07 AM
  17. billyblue123's Avatar
    I m using the s4 LTE since 20 days and its driving me crazy, LAG LAG LAG. I have done all possible ways to fix this issue but still not working, i have swtiched off all Apps and i am using my S4 only for calls and smss and thats heart breaking to see such a beautiful device and can't use it.
    Any solution? the phone is not responding and very slow in all apps even when i send sms its just taking ages.
    Whats the solution? should i go back to Blackberry Q10?
    06-08-2013 04:03 PM
  18. fishepa's Avatar
    Sound like you have an issue. I would reset the phone. I don't have any of your issues.
    06-08-2013 09:10 PM
  19. crester's Avatar
    I think SwiftKey uses a lot of resources... I noticed my phone started being smoother ever since I started using the Google Keyboard.
    06-09-2013 01:24 AM
  20. newS4owner's Avatar
    yeah swiftkey showed 33MB memory use on my s4, uninstalled it.
    06-09-2013 01:35 AM
  21. Comp625's Avatar
    I have an s3 and definitely notice a SwiftKey lag if either Smart Rotation and/or Auto Rotation are enabled. The keyboard is very laggy, especially in landscape mode.
    It's such a shame because the prediction algorithms are superb with SwiftKey, rather than on the stock Google Keyboard (which is arguably smoother and lag free) and especially compared to the stock Samsung keyboard (the worst of the three).
    Sent from my SCH-I535 using Tapatalk 4
    10-05-2013 11:26 AM
  1. Replies: 2
    Last Post: 05-27-2013, 12:11 PM
  2. Replies: 0
    Last Post: 04-24-2013, 08:40 PM
  3. [SwiftKey] Swiftkey out of beta, but not in the market?
    By storm6610 in forum Keyboards
    Last Post: 09-30-2010, 09:36 PM
  4. [SwiftKey] swiftkey causing force close of all apps
    By J-Buck#AC in forum Keyboards
    Last Post: 09-30-2010, 12:00 PM
