1. elbaby's Avatar
    I set a 30 second song clip as my notification sound for games, email and MMS. On other phones I've had, the song would always stop after I have checked/cleared the notification. However, on my Galaxy S4, it plays the song in its entirety even after I've checked the notification and cleared it.
    If I get a 2nd notification a few seconds after the first one, the sound plays AGAIN, so the song is playing TWICE, one layered on top of the other at different points of the song. It is driving me nuts. Any solutions???
    06-03-2013 05:58 PM
  2. friedtators's Avatar
    Can you check to see if play as a clip is an option. That's painful. Make you hate the tune quick
    06-03-2013 06:06 PM
  3. elbaby's Avatar
    Don't see that as an option
    06-03-2013 06:31 PM
  4. smooth4lyfe's Avatar
    30 seconds long for a notification?
    I should try making it shorter...there are audio editing apps in the Play Store that you can use to make it shorter
    06-03-2013 06:56 PM
  1. Notification sound won't change
    By thirdeye82 in forum Verizon Droid Incredible
    Last Post: 12-10-2016, 02:30 PM
  2. Notification light won't stop blinking
    By cubiclegeoff in forum Droid RAZR MAXX
    Last Post: 05-14-2014, 10:13 PM
  3. Plate Breaker, Addicting Game You Won't Stop Playing
    By amagineinteractive in forum Android Games
    Last Post: 04-24-2012, 12:47 AM
  4. How to make notification sound for Gmail stop?
    By SuzisZoo#AC in forum Verizon HTC Thunderbolt
    Last Post: 09-25-2011, 10:12 PM
  5. Notification flash won't stop.
    By gwtiff54 in forum Verizon HTC Thunderbolt
    Last Post: 09-25-2011, 02:46 PM
