1. sedative's Avatar
    I'm trying to figure out if I'm the only one.. I bought a brand new 32gb gs4, and it would randomly lose radio connections (bluetooth,wifi,mobile data)..
    Well after a software update and a weeks worth of use it was still happening, so I just went back to AT&T and they swapped it out for another one.
    The second one came updated and is still having similar problems. Now I'm just randomly losing the mobile data connection, although I have 3-5 bars and I'm on 4G.
    The only way I've been able to get my mobile data connection back is to flip airplane mode on and off, or tap the mobile data button on and off.
    Is anyone else having similar problems? I'd like to know if its a software thing before I go back and have them swap it AGAIN.
    06-04-2013 06:44 PM
  2. friedtators's Avatar
    I would replace sim first. Does this happen mostly in one area?
    06-04-2013 08:08 PM
  3. nyc_rock's Avatar
    32gb here. No connection issues. Battery life is awful but that's a story for another day.
    06-04-2013 08:43 PM
  4. sedative's Avatar
    They did replace the sim on the first device I had, and it was still happening so they used the same sim for the new device. It happens all over in a 50 mile radius that I've been in. It happens while I'm using it or when it's been sitting idle and I pick it up and try to use it it'll have no data connection.
    06-05-2013 08:46 AM
  5. friedtators's Avatar
    make it their problem
    06-05-2013 08:47 AM
  1. Droid connection Problem (no 3G or 1x)
    By corydunbar in forum Motorola Droid
    Last Post: 04-25-2015, 09:18 AM
  2. 4g connection problem fixed quick look at this
    By sergio_sss in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-06-2010, 01:20 AM
  3. WIFI connection problems
    By Raija in forum HTC Desire
    Last Post: 05-20-2010, 05:24 AM
  4. Bad 3g Connection Problems?
    By ClickClack911 in forum HTC Droid Eris
    Last Post: 02-02-2010, 08:35 PM
  5. GTalk on Moto Droid Connection Problems?
    By n2o in forum Motorola Droid
    Last Post: 11-11-2009, 12:31 PM
