1. skipreid45's Avatar
    This is my first Galaxy phone. I have a 64GB Sandisk card. I have only saved 2 pics from Firefox, 2 more pics and 2 music files attachments from my email. All of
    these are saving to the internal memory though. I even went into the My Files app and "moved" them onto my card. However.....when I look
    at the storage menu, all of the items are still under the internal memory, and I have just have an un used SD card that is completely empty.
    Am I not doing something correct? It seems like something should be showing up on the sd card. I have read many other problems with the storage,
    but at least they seem to be able to get something such as music and pics on their cards. It's frustrating and probably an easy fix that I cannot
    figure out, since I am new to this phone.
    06-06-2013 10:28 AM
  2. friedtators's Avatar
    so if you remove the card to your pc the files are not there?
    06-06-2013 10:44 AM
  3. srkmagnus's Avatar
    Make sure the sd card is properly formated (FAT32) on a computer then put back into the phone and mount. It should fix the problem.
    06-06-2013 11:04 AM
  4. skipreid45's Avatar
    Thanks srkmagnus. I will try that.
    06-06-2013 11:21 AM
  5. srkmagnus's Avatar
    Let us know how things work out.
    Sent from my SPH-D710 using Tapatalk 2
    06-06-2013 10:18 PM
  6. skipreid45's Avatar
    It worked like a charm. Thanks so much.
    06-10-2013 08:47 AM
  1. can texts be saved to sd card
    By blunt420 in forum Verizon Droid Incredible
    Last Post: 07-10-2013, 04:39 AM
  2. Help moving pix to sd card
    By ctychick in forum Verizon Droid Incredible
    Last Post: 07-05-2010, 11:57 PM
  3. What's best app to explore and save to SD Card and built in phone storage ?
    By jasonvancouver in forum Verizon Droid Incredible
    Last Post: 07-02-2010, 08:33 PM
  4. how to delete pictures saved to sd card ??
    By thatguy in forum General Help and How To
    Last Post: 01-10-2010, 01:37 PM
  5. how to delete pictures saved to sd card ??
    By thatguy in forum HTC Droid Eris
    Last Post: 01-10-2010, 01:07 PM
