1. StuartV's Avatar
    I plug my charger that came with my phone (a VZW S4) into my phone and run the Galaxy Charging Current app (from the Play store).
    It shows 1900 every time. I have unplugged it and plugged it back in numerous times and clicked Refresh and it always shows 1900.
    Last night, I tried plugging my g/f's charger for her Note 2 into my phone. The first time, my phone said it was charging, but GCC showed 460. I unplugged and replugged a few times and each time after that it showed anywhere from 1600 - 1700, but it never showed 1900. I switched back and forth between hers and mine several times, plugging them both into the same wall outlet. Mine still showed 1900 every time.
    I thought maybe it was a different charger that just looks the same, but the part numbers on them are identical. ETA-U90JWS
    Each charger was connected via the cable that came with it. I guess I should have tried swapping cables, but I didn't think of that at the time.
    Any idea what's up with that? Shouldn't the charger from a Note 2 work just the same as the charger that came with my S4?
    06-06-2013 10:43 AM
  2. friedtators's Avatar
    batteries the difference i would suspect
    06-06-2013 11:40 AM
  3. StuartV's Avatar
    How's that? As I said, I was connecting my S4 to both chargers. So, the battery (and phone) were the same in all the cases I was talking about.
    06-06-2013 11:53 AM
  4. friedtators's Avatar
    i obviously read it as difference between hers his phone.
    06-06-2013 12:36 PM
  5. SpookDroid's Avatar
    I've tried the charger from my old Note 2 and the S4 one, all work fine. It could be the USB cable (I did notice the S4's is longer, which is appreciated) or your GF's charger is just defective/older. Both chargers are able to output 2A, so it should work just fine. Just for comparison's sake, I also use a Sony Cybershot USB Charger that also outputs 2A via USB and it works perfectly with the S4...
    StuartV likes this.
    06-06-2013 02:01 PM
  1. using non samsung charger
    By heclaboy82 in forum Sprint Nexus S 4G
    Last Post: 05-09-2011, 04:56 PM
  2. Verdict: using blackberry pwr charger
    By anonymous239411 in forum Verizon HTC Thunderbolt
    Last Post: 03-23-2011, 07:46 PM
  3. Will It Hurt My Phone To Use a Blackberry Charger?
    By miamifin33 in forum Motorola Droid X
    Last Post: 07-16-2010, 10:19 AM
  4. Replies: 6
    Last Post: 06-22-2010, 07:31 PM
  5. Okay to use BlackBerry Tour charger?
    By ThirstyTurtle in forum Motorola Droid
    Last Post: 11-11-2009, 06:32 PM
