1. srt05wv's Avatar
    I have like 1 or 2 decently thick vertical lines going from top to bottom of screen. Most noticeable at low brightness and on white or gray backgrounds. Its nothing major that causes a visibility issue, its just kind of annoying and wondered if I should return it? If I did return it chances are they wont even see them because theyre not noticeable unless u try to look..
    06-08-2013 07:21 PM
  2. bosshaug12's Avatar
    If you're within your 14 day return window they can't tell you no. Plus since you are experiencing a defect you should definitely return it before the display gets worse or even fails completely. The S4 screen is a pretty expensive part to replace so if you can return it you should.
    chrscaley likes this.
    06-08-2013 10:39 PM
  3. orion575's Avatar
    I got 3 or 4 same vertical lines on my screen too, but they don't really bother me cause I can barely see them
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
    06-08-2013 10:40 PM
  4. chrscaley's Avatar
    +1. Exchange it while you still can.
    06-08-2013 10:41 PM
  1. No one answers asus help line
    By billsmam in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 01-29-2013, 05:19 PM
  2. I assume no one else can use the tele nav
    By jmiles3010 in forum Sprint Galaxy Nexus
    Last Post: 05-22-2012, 10:29 PM
  3. HTC EVO 4g free service. Any one else experiencing this?
    By kermanjake in forum Software Development and Hacking
    Last Post: 02-06-2012, 08:49 AM
  4. Seriously, no one else's browser is crashing when they edit text?
    By BlackHawkA4 in forum Sprint Nexus S 4G
    Last Post: 08-07-2011, 12:56 PM
  5. Anyone else feeling like they'll be trading in their TB in 4-5 months?
    By durangojim#AC in forum Verizon HTC Thunderbolt
    Last Post: 03-19-2011, 12:09 PM
