1. chuck w1's Avatar
    Hello I just recently upgraded from a droid X to the Galaxy S4. I have installed all computer drivers so that I can connect to the internet using PDAnet. It works and the computer recognizes the phone but only as a media device with no content. I know for my droid X the SD card would be recognized however on the S4 it is not. I have a 16GB SD card in the phone but the computer is not recognizing it. Any ideas how to get it to show up? Please and thank you
    06-09-2013 07:59 AM
  2. friedtators's Avatar
    i would trouble shoot card. put in a pc and move a file to it and then open the file on the sd. if so the cards good.. there is a setting for storage sd card does it show the total space? does it show mounted?
    can you use my files app to see the files on card and access them?
    06-09-2013 08:24 AM
  3. monsieurms's Avatar
    Particularly that last...does the phone recognize the card? If you bring up File Manager on the phone, does it see the Card? Can you pull up music files on the card and play them with the music player?
    If not--maybe the card is (a) defective (b) unformatted or (c) not properly installed.
    If it is not a problem with the card itself, I'm unsure what to do. When I attach my phone with card to the computer, it just pops up, gives a choice of opening device, and shows me both the phone and the card as icons to select.
    06-09-2013 08:26 AM
  4. blewvelvet's Avatar
    I was having problems seeing my files on and SD cards and USB stick. Once I formatted them to exFAT..and recopied my files to them....it totally worked!
    Use the exFAT File System and Never Format Your External Drive Again
    06-12-2013 10:34 AM
  1. SD card help
    By qsjoint25 in forum Verizon HTC Thunderbolt
    Last Post: 04-18-2011, 11:14 AM
  2. trying to install 32gb sd card... help! epic 4g
    By Dw4980 in forum Sprint Epic 4G
    Last Post: 03-26-2011, 10:48 PM
  3. sd card help
    By hudson5672 in forum General Help and How To
    Last Post: 03-06-2011, 02:13 PM
  4. Samsung Transform - SD card help
    By chaosreins in forum General Help and How To
    Last Post: 02-21-2011, 06:27 PM
  5. Sd card help!!!
    By jbuggydroid in forum Software Development and Hacking
    Last Post: 07-11-2010, 04:10 PM
