1. Zendroid1's Avatar
    I am most interested in the gesture to preview when your screen is turned off and your phone is laying flat. I have turned on air gestures and restarted/rebooted many times but no matter how many times i swipe my hand over the sensor the preview will not show.
    Am i missing out on turning some option on or something? I am using nova launcher prime.
    06-09-2013 05:48 PM
  2. irishonion's Avatar
    Is quick glance on? If you long press the "Air Gestures" on the toggle menu you can turn the mode "Quick Glance"
    06-09-2013 06:07 PM
  3. smooth4lyfe's Avatar
    When you go to settings and "Motion Gesture", click on "Air Gesture" and it should open up another option, which allows you to turn on "Quick Glance" and a few others as well
    - - - Updated - - -
    06-09-2013 07:01 PM
  4. Zendroid1's Avatar
    I hereby nominate myself ***** of the day. Thanks guys.
    06-09-2013 08:29 PM
  5. JoeyyNY's Avatar
    Lol pretty funny.
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
    06-09-2013 08:40 PM
  6. Bmanchan01's Avatar
    Hey folks. I thought I was bugging out also because none of my gestures were working. But listen to what I say. YOU LITERALLY HAVE TO TURN ON EVERY GESTURE OPTION.
    MENU > SETTINGS > MY DEVICE > AIR VIEW (SLIDE THAT TO ON AND THEN TAP IT TO BRING UP THE SUB MENU AND MAKE SURE EVERYTHING IS CHECKED)
    then go back
    TAP MOTIONS AND GESTURES AND MAKE SURE EVERYTHING IS CHECKED IN THERE ALSO. ONLY 2 OF THE GESTURES WORKED ON MY PHONE AND AFTER MESSING WITH ALL THESE SETTINGS I WAS ABLE TO GET ALL THE GESTURES TO WORK AND CONFIRMED THEM TWICE.
    THIS WORKED FOR ME AND HOPE IT WORKS FOR YOU GOOD PEOPLE :-)
    06-17-2013 03:32 AM
  7. eacohen109's Avatar
    Tried everything Bmanchan01 suggested but still nothing. Also I don't even see the hand icon on top. And yes I restarted. Help?
    08-05-2014 03:37 PM
  1. my air gestures don't work
    By Davidjacobs21 in forum Samsung Galaxy S4
    Last Post: 09-12-2014, 11:17 PM
  2. Air view for messages suddenly not working
    By scottadus in forum Samsung Galaxy S4
    Last Post: 04-30-2013, 01:35 PM
  3. Kies Air not working recently..
    By tchung84 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 10-12-2011, 10:10 PM
  4. Locale and Astrid not working
    By emooney in forum HTC Hero
    Last Post: 10-20-2009, 10:24 AM
