vasekvi
The issue ended up being with my OEM usb micro cable. It was only putting about 420mA to the phone. After trying another cable with the charger it made all the difference in the world. It now charges in about two hours.
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
Glad you were able to find the problem. I wonder if the cables just mess up or bend pins or if using a cheap cable messes up the usb port on these phones sometimes. I used an El cheapo cable at work to do a file transfer and after it didn't want to seem to charge. This was before I had the widget to verify charge rates. No more cheapo cables for me. And once I get my inductive coil this is what will be residing in the two lint and dust collectors on my phone.
Sent from my AT&T Samsung Galaxy S4 using Tapatalk II
