1. DayananBaptist's Avatar
    Hi guys,
    When I send a picture through MMS, it seems like the phone compresses the picture. Is there anyway to disable this compression and just send the full size picture?
    Thank you!
    06-12-2013 11:28 AM
  2. Almeuit's Avatar
    Most (if not all) message apps compress the picture. You can try others to up the limit in the file size but remember your carrier will compress or even reject the file if to big.
    Sent from my Sprint S3 using AC forums.
    odd likes this.
    06-12-2013 01:45 PM
  3. shaw1234's Avatar
    If you can't compress it, just use email. MMS is limited by carrier. I believe on Verizon you can't MMS an image larger than 1Mb.
    Sent from my SCH-I545 using AC Forums mobile app
    06-12-2013 01:47 PM
  4. odd's Avatar
    Beyond using email, an app like Groupme is pretty good with sending images, both parties just need to have groupme installed - https://play.google.com/store/apps/d....android&hl=en
    06-12-2013 02:12 PM
  1. Replies: 1
    Last Post: 01-31-2013, 10:34 AM
  2. General Network Failure when sending photo via MMS
    By mtech#WN in forum Verizon HTC Rezound
    Last Post: 12-20-2011, 02:33 PM
  3. Send MMS issues?
    By JDAustin in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-02-2011, 11:50 AM
  4. Force closes when sending MMS
    By slschmidt76 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 10-07-2011, 01:16 PM
  5. Issue when sending a text to multiple recipients
    By jaymzb0nd in forum HTC myTouch 4G
    Last Post: 08-09-2011, 09:17 PM
