1. jayarh1's Avatar
    I have swipe to unlock and at times the lock screen won't register my swipes to unlock screen. I have found a few work arounds like going thru s-voice theb backing out and theres also pulling down the notification window and going to settings then backing out. I was just wondering if anyone else has this issue or knew a fix for this
    06-13-2013 07:25 PM
  2. swent1's Avatar
    Had the same issue. It ony happened once and I ended up just restarting the phone and it hasnt happened since
    06-13-2013 08:07 PM
  3. hallucinojerk's Avatar
    I had a screen issue since and what I did was to wipe data from recovery and it went away.
    06-13-2013 08:16 PM
  4. jayarh1's Avatar
    Thanks for your replies the problems still persistent for me even after a restart and I'm really trying avoid a wipe since I'm still getting used to android again
    06-14-2013 01:45 AM
  5. svitore's Avatar
    I find after a restart the problem ceases only temporarily. only swipes for short cuts are recognized. i'm also trying to avoid wiping it.
    jayarh1 likes this.
    07-09-2013 12:46 PM
  6. CRUZOPS's Avatar
    I was having the same problems and I uninstalled GO Launcher EX. I'm now using the stock launcher for my Samsung S4 -- I have no more issues. Hope this helps.
    08-04-2013 10:07 PM
  7. beenipp's Avatar
    I'm having same problem....and sometimes I can't answer a call
    08-08-2013 05:24 PM
  8. hectorvalero's Avatar
    I've had all those issues, can't answer a call, hang up or press keypad for 1 etc..I just found online about disabling S-Voice from the home button and in Developer Options removing all effects. Sucks but at the end of the day I need it to work. I can do without animations.
    10-15-2013 08:49 PM
  1. Unresponsive lock screen
    By JGK123 in forum Google Nexus 4
    Last Post: 12-29-2012, 04:42 AM
  2. Lock screen unresponsive? (NOT charger related)
    By Taz420NJ in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-10-2011, 03:27 PM
  3. Unresponsive lock screen
    By KoukiFC3S in forum Sprint Nexus S 4G
    Last Post: 05-18-2011, 11:39 PM
  4. Lock screen is unresponsive
    By griswolds53 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 03-02-2011, 01:14 PM
  5. lock screen unresponsive
    By gigatigga in forum Sprint Epic 4G
    Last Post: 09-08-2010, 08:44 PM
