1. tohio's Avatar
    if people are disconnecting their USB connection between their S4 and their computer without using the Safely Remove Hardware and Eject Media program. Disconnecting the SD card while read write operations are in progress might cause corruption.
    06-14-2013 12:27 AM
  2. GS4Bob's Avatar
    My connections are WiFi, so no issues with that here and I still find my SD card needs to be mounted at times on reboot.
    06-14-2013 08:14 AM
  1. SD Card problem after froyo
    By ArtieTheOneManParty in forum Motorola Droid X
    Last Post: 11-17-2010, 10:41 PM
  2. Micro sd card problem nothing comes up when i put it in my laptop?
    By jounchip in forum Software Development and Hacking
    Last Post: 07-21-2010, 06:09 PM
  3. Unrevoked Evo having SD Card problems
    By RyboCollier in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-24-2010, 01:56 PM
  4. SD card problem
    By JesseJames101 in forum Verizon Droid Incredible
    Last Post: 05-30-2010, 08:13 AM
  5. Droid sd card problems?
    By azezial in forum Motorola Droid
    Last Post: 11-30-2009, 02:23 PM
