1. Odd Future's Avatar
    Is there a app that allows you to use any app in multi window without rooting my phone?
    06-14-2013 03:03 AM
  2. satannik's Avatar
    Try multi window manager. I don't remember if it asked me for root.
    06-14-2013 03:09 AM
  3. Raymond Tan's Avatar
    Multi window manager needs root.
    Here is a link to a method to make almost any app multi window without rooting(need PC and apk file of original app)
    [Tool] Add Multiwindow-option to almost every apk files - xda-developers
    Here is a link to apps that have been already run through the process to add multi window, but I suggest doing it yourself because some the the apks are older versions.
    [APP] Multiwindow Apps - xda-developers
    The disadvantage of this method is that you will not get updates for the app. If an update is available you will have to get the new apk and run it through the process again.
    Apk. files can be retrieved by using an app backup application. Most apk. files can be gotten this way, but some apps can not be backed up.
    06-14-2013 04:21 AM
  4. monsieurms's Avatar
    The only bad thing about this feature and others like hover is that they don't work on most 3rd party programs. Wish they did.
    06-14-2013 09:57 AM
  1. Multi-tasking question
    By dornier in forum HTC Hero
    Last Post: 04-08-2013, 05:20 PM
  2. Question about 'Beans' 10 multi-window feature ...
    By ejb1013 in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 03-12-2013, 09:40 AM
  3. Multi window feature from note 2
    By Nazty111 in forum Samsung Galaxy S3
    Last Post: 10-06-2012, 06:31 PM
  4. Multi Windows function
    By popologuy in forum Samsung Galaxy Note 2
    Last Post: 10-05-2012, 11:23 PM
  5. Multi-windows on Android?
    By thrillhouse847 in forum General Help and How To
    Last Post: 10-02-2010, 09:32 PM
