1. benhaw's Avatar
    About 2 weeks ago I kicked my i5 to the curb and got a GS4. I have loved just about everything on this phone except for the occasional lag and one other problem.. For some reason, the phones screen lights up every hour exactly just as if i had pushed the home button. It stays on for about 5 seconds. The phone lights up at 1:45, 2:45, 3:45 etc.. I'm sure its an app that I installed doing it but is there any way I can find out which one it is? It's been doing it basically since I got it and i don't want to just start uninstalling everything and then waiting an hour to see if it will turn on.
    It's not the worst problem to have and I get that, I just want to understand haha because its so weird. Any help would be appreciated.
    06-14-2013 03:51 PM
  2. Golfdriver97's Avatar
    Welcome to Android and the forums!!
    It may not be an app you downloaded, but a stock one that refreshes once an hour.
    Sent from a M.O.A.R. Galaxy S3
    06-14-2013 04:09 PM
  3. monsieurms's Avatar
    My turns on periodically when, I presume, it is doing something in the background. It doesn't happen often. But I presume most have security for their lock screen. As long as you have security, when it turns on, it looks for a password and without one, it turns off in a few seconds. Otherwise, it may take until the normal "no activity" time out.
    06-14-2013 04:46 PM
  4. fou's Avatar
    I'm not sure about the time frequency, but mine does the same. Even with blocking mode turned on so I don't get notifications at night while sleeping, the phone will just light up and it is very annoying.
    06-15-2013 07:43 AM
  5. Hikmat abdoollayev's Avatar
    Have you solved this issue?
    I would like to recommend another solution.
    There must be some apps which lighting up your screen.
    You can detect them by using "Wakelock detector" app!!
    09-05-2013 11:55 PM
  6. jeffreii's Avatar
    I suggest you download Wakelock Detector:
    https://play.google.com/store/apps/d...kelockdetector
    Once installed, wait until your screen turns on automatically. Then go to Wakelock Detector and check out the "Screen Wakelocks". It should be listed there.
    09-08-2013 11:14 PM
  1. Unable to Root Aria for Some Reason
    By Tuckerfan in forum HTC Aria
    Last Post: 03-11-2012, 03:01 PM
  2. Samsung Mesmerize screen lights up for no reason
    By imnotnotjoe in forum U.S. Cellular Mesmerize
    Last Post: 11-26-2011, 05:19 PM
  3. Droid X keeps waking up every hour....wtf?
    By Matrix_Prime in forum Motorola Droid X
    Last Post: 02-10-2011, 05:57 PM
  4. 3G lighting up every time I unlock device?
    By splmonster in forum HTC EVO 4G
    Last Post: 10-09-2010, 04:20 PM
  5. Screen light up with text?
    By cobra302 in forum AT&T Captivate
    Last Post: 07-23-2010, 06:39 PM
