1. chloeshotmom's Avatar
    is this normal? i was charging this morning when i noticed that it was very hot on top and upper back. and my battery drains so fast. i have a lot of apps running when i checked the application manager but i dont know which one to disable or stop.
    06-14-2013 05:31 PM
  2. VDub2174's Avatar
    That happened to an HTC One X I had on my account and it turned out bad. It ended up getting burn marks on the back and it wouldn't turn on at times. I would take it to ta store when it over heats.
    06-14-2013 09:15 PM
  3. Aaron Watson's Avatar
    Well, my s3 gets a little warm when it's charging and a little hot while using it while charging but dont worry its normal. It shouldnt get very hot tho. Even my bro's iphone 4s gets warm while charging. Probably just the way it is
    06-14-2013 09:41 PM
  4. chloeshotmom's Avatar
    its not warm, its really hot in front and back. after charging its gone.
    06-14-2013 09:46 PM
  5. VDub2174's Avatar
    Get that checked out. Same thing happened to my dad's phone on my account. I had it replaced eventually.
    chloeshotmom likes this.
    06-14-2013 10:05 PM
  6. chloeshotmom's Avatar
    thank you... i have soooo many problems with my phone and im so dissappointed right now.
    06-15-2013 12:04 AM
  7. Jennifer Stough's Avatar
    You pay a premium for a premium device, if you feel for any reason that it is not running 100% as it should, please, return it. There is no reason why you shouldn't get what you pay for
    06-15-2013 12:08 AM
  8. mysticmeg's Avatar
    yaay woo hoo well said.
    Sent from my GT-I9505 using Tapatalk 2
    06-15-2013 01:15 PM
  9. onick's Avatar
    Do a factory reset to see if your problem is fixed. If not, take it back.
    Sent from my GT-I9100 using AC Forums mobile app
    06-15-2013 02:35 PM
  10. chloeshotmom's Avatar
    so, after one month of having this phone its still extremely hot when i am talking to the phone for 3 mins. i cant put the phone in my ear anymore. i dont have games, music on my phone. gps is off and all the smart and air thing.
    i called ATT for replacement but they dont want to replace it. i got it on june13. they will just send me a battery and thats it. is it really the battery?
    07-24-2013 04:24 PM
  11. s4user1's Avatar
    I think (but not sure). It's the chipset.
    Have u updated the firmware ?
    Sent from my GT-I9500 using AC Forums mobile app
    07-24-2013 05:44 PM
  12. chloeshotmom's Avatar
    No updates yet...
    07-24-2013 06:36 PM
  13. chloeshotmom's Avatar
    Updates:
    ATT send me a brand new phone last week and it doesnt get hot at all. the phone is faster than the old one. Doesnt lag at camera and album/gallery. the only problem is the speaker is broken. but overall based on my previous posts about the problem on my s4 before, everything is fine now.
    VDub2174 likes this.
    10-03-2013 09:52 AM
  14. VDub2174's Avatar
    Glad to hear that AT&T sent you a new one
    10-03-2013 10:12 AM
  15. chloeshotmom's Avatar
    yup that was my 3rd s4 since june. lol
    and this time they will send me another phone because of the broken speaker.
    10-03-2013 10:29 AM
  16. STSVA's Avatar
    Let us know how that one turns out - hope it's 100% this next time.
    10-03-2013 11:52 AM
  17. VDub2174's Avatar
    Here's to hoping you get a FULLY functional phone this time around.....haha
    10-03-2013 12:36 PM
  1. Screen won't turn off when charging
    By gatortuba in forum Verizon Droid Incredible
    Last Post: 08-02-2010, 04:49 PM
  2. No Soft Buttons work when charging
    By Charmed Juan in forum Verizon Droid Incredible
    Last Post: 07-26-2010, 12:06 PM
  3. Can't access phone storage when charging via USB
    By kirk in forum AT&T Captivate
    Last Post: 07-19-2010, 03:27 PM
  4. Screen stays lit when charging?
    By gm2376#AC in forum Motorola Droid X
    Last Post: 07-16-2010, 05:54 PM
  5. Keep screen on when charging
    By wabyrd in forum Motorola Droid X
    Last Post: 07-15-2010, 07:58 PM
