1. Orador223's Avatar
    Ok, so I've had the verizon s4 for a few weeks now and i really just noticed this issue. When I am playing music and i click on the music settings button, the volume in my left ear increases, is anyone else experiencing the same issue? How can i fix it? Thanks
    - - - Updated - - -
    Also the volume starts to change automatically after listening for awhile
    06-16-2013 12:46 AM
  2. meandthecolors's Avatar
    Try deactivating voice control if you dont need it. Did the trick for me! It must have something to do with voice recognition, it'll probably be corrected in an upcoming update.
    Orador223 likes this.
    06-16-2013 12:59 PM
  3. Orador223's Avatar
    Yes! Thank you!! It worked! Sadly I won't be able to use my voice commands when driving anymore, oh well
    06-16-2013 10:44 PM
  1. Help with music app? Sound increases when i click on settings..
    By Orador223 in forum Verizon Samsung Galaxy S4
    Last Post: 06-16-2013, 04:54 PM
  2. Where is play music app files stored when pin for "on device"?
    By steelhand69 in forum General Help and How To
    Last Post: 12-04-2012, 04:12 PM
  3. Help with music shutting down when sleeping
    By Bosgarage57 in forum Verizon HTC Rezound
    Last Post: 12-22-2011, 12:32 PM
  4. help with radio apps
    By Dcm210 in forum Motorola Backflip
    Last Post: 03-09-2011, 03:00 PM
  5. Need Help with Facebook App
    By olson0827#AC in forum Android Apps
    Last Post: 11-11-2009, 09:25 PM
