1. Odd Future's Avatar
    Whenever I try to save/download pictures they never show up in my gallery. They save if I screenshot them but not pics from Google. I do have a sd card in
    06-16-2013 10:21 PM
  2. Joe Vile's Avatar
    Same problem here. Saving pics from Twitter and can't find them any where
    06-17-2013 04:26 AM
  3. Rirruto's Avatar
    I saved a picture from Twitter and it saved to /storage/emulated/0/dcim/camera/
    I saved a picture from Chrome and it saved to /storage/emulated/0/download/
    I use Quickpic as my photo viewer
    06-17-2013 11:34 AM
  4. skipreid45's Avatar
    I use Plume for Twitter and Firefox as browser. All of the photos I save are going to a "download" folder on the sd card. I can easily see them under the Gallery and Quickpic app.
    06-17-2013 12:10 PM
  5. Joe Vile's Avatar
    @rirruto cheers mate. Found them all. Any suggestions on how to change default folder?
    06-17-2013 01:42 PM
  6. paintdrinkingpete's Avatar
    It depends on the app you use...some have options to change, so do not. If you're rooted, there are ways to circumvent default saving locations, but otherwise sometimes you are stuck.
    Note: Some apps will, by default, place a ".nomedia" file in the directory where it saves stuff, specifically to avoid having those files appear in the Gallery.
    06-17-2013 01:46 PM
  1. weird picture text problem anyone else?
    By kroman1107 in forum Motorola Droid X
    Last Post: 08-10-2010, 10:02 PM
  2. Pictures save where?
    By Mister869 in forum Motorola Droid X
    Last Post: 08-05-2010, 11:20 AM
  3. Picture message problem
    By dharding6 in forum HTC Hero
    Last Post: 02-23-2010, 06:49 PM
  4. how to delete pictures saved to sd card ??
    By thatguy in forum General Help and How To
    Last Post: 01-10-2010, 02:37 PM
  5. how to delete pictures saved to sd card ??
    By thatguy in forum HTC Droid Eris
    Last Post: 01-10-2010, 02:07 PM
