12-11-2017 01:55 PM
88 ... 234
tools
  1. An ONEs's Avatar
    Thank you. After exploring the Internets for an hour I finally found your solution and it worked for my Samsung Grand. Thank you for saving me a trip to the Sprint store or calling their terrible customer service. You are awesome.
    04-23-2016 12:39 PM
  2. kalid shafi's Avatar
    Thank you very much I have get satisfaction from your answer
    06-03-2016 03:55 PM
  3. Arshad Solehry's Avatar
    This worked for me.
    06-25-2016 09:07 AM
  4. 11B11's Avatar
    Thank you for the video. Very helpful. This worked for me. Thank you. I am very grateful.
    07-21-2016 09:56 PM
  5. Roger Brown3's Avatar
    First go to Settings > Security > Device Administrators.
    Deactivate all programs there.
    then go back to Security and click clear credentials at the bottom of the page.
    That is what worked for me after using AirDroid.
    Hey. Just wanted to say thanks. Had the same problem and you really helped.
    08-11-2016 06:50 PM
  6. Isuru Perera1's Avatar
    Yes it worked.
    09-21-2016 12:29 PM
  7. aakash mehta2's Avatar
    Thanks its works for me also.
    10-07-2016 11:35 PM
  8. anonymous person1's Avatar
    10-18-2016 01:00 PM
  9. anonymous person1's Avatar
    It worked for me you are genius thank u so much
    10-18-2016 01:01 PM
  10. jignesh yadav's Avatar
    If anything don't help you
    You can do this
    Setting>security>apps with usage access
    and find a screen lock app and turn off
    04-02-2017 07:13 AM
  11. 100 YouTube Subscribers's Avatar
    Same issue on my Galaxy Tab E Lite. Clearing the credential storage fixed it.
    08-22-2017 12:47 AM
  12. SherriBabeee's Avatar
    THANK YOU !!
    Samsung Note 3 (N900v)
    My phone has been locked for MONTHS !
    Just found this thru Google Search and It worked !
    "Clear Credentials"
    Couldn't figure out what I did....
    THANK YOU Folks !
    11-22-2017 02:07 AM
  13. Patricia Tovar's Avatar
    thanks guys this helped me.. thanks again..
    12-11-2017 01:55 PM
88 ... 234
  1. Hi, I'm new to Android OS and Galaxy Note. Help with USB storage!
    By trinxified in forum Samsung Galaxy Note
    Last Post: 04-18-2013, 03:46 AM
  2. Galaxy Camera Help with settings please...
    By fires999 in forum General Android Device Chat
    Last Post: 01-14-2013, 08:03 PM
  3. Hi, I'm new to Android OS and Galaxy Note. Help with USB storage!
    By trinxified in forum General Help and How To
    Last Post: 02-23-2012, 09:56 PM
  4. Galaxy Note: Help with the Handwriting Mode
    By allansy in forum Samsung Galaxy Note
    Last Post: 11-28-2011, 09:40 PM
  5. New Android owner- att galaxy tab help with Root or sideloading
    By dentalexel in forum Samsung Galaxy Tab
    Last Post: 05-20-2011, 08:36 AM
