1. panderbeer's Avatar
    got my phone a month ago and i just noticed around 2 weeks ago that my phone heats up while charging. it says in my charger output: 5.0V---2.0A. how do i stop it from heating up?
    also what's the normal battery life of an S4? my wifi is off, phone is on silent mode, it's also on power saving mode and my screen brightness is at its lowest. from 100%, it goes down to around 85% in about 2-3 hours and the only thing i do is send an sms and make a few like 2 short calls (less than a minute calls). more often than not, i dont make a call. so i only text but i dont also text that often. is this normal?
    thanks!!!
    06-17-2013 04:02 PM
  2. Almeuit's Avatar
    I can't comment on your battery drain but I can comment on the heat. That's normal.. As the battery charges it will get a little warmer.. It shouldn't be super hot or anything but I do know my S3 has always warmed up a little while charging.
    Sent from my Sprint S3 using AC forums.
    06-17-2013 04:48 PM
  3. panderbeer's Avatar
    thank you!!
    06-21-2013 01:40 PM
  1. Replies: 82
    Last Post: 04-28-2016, 09:22 AM
  2. Samsung Galaxy S4 Heat Issue
    By jsmlee1207 in forum Samsung Galaxy S4
    Last Post: 04-11-2014, 12:19 PM
  3. Replies: 2
    Last Post: 05-30-2013, 08:14 PM
  4. Samsung Galaxy S4 screen turns to green and make a high pitched screeching noise
    By Thien Trinh in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-22-2013, 10:10 AM
  5. Samsung Galaxy S4 To Get 'Eye Pause' And 'Eye Scroll'
    By deesugar in forum Samsung Galaxy S4
    Last Post: 01-30-2013, 03:14 PM
