1. cessperience's Avatar
    My phone is more than a month old and been using mobile data without problems until tonight. My phone not showing the H+ or 4G icon anymore.
    - Can receive SMS and calls
    - Can connect to WIFI
    I tried the following solutions but still no luck.
    - Soft and Hard Reset. No luck so I've Factory Reset but no use
    - Toggled on and off the Mobile Data at Settings
    - Tried switching Network Modes (LTE, GSM, etc)
    - Tried changing Network Operators
    Thanks in advance for your help.
    06-18-2013 11:28 AM
  2. D R Lewis's Avatar
    There is a problem with this on the phones. I got help through Verizon!!
    06-18-2013 11:37 AM
  3. Almeuit's Avatar
    I assume your ATT so I'd check with them to see if they can help. Calls and SMS mean your connected to the towers and that's what calls / SMS use. However the data part is another element and for some reason your phone won't work.
    Sent from my Sprint S3 using AC forums.
    06-18-2013 11:51 AM
  1. No mobile data with custom rom on unlocked g2x
    By toddrosenberger in forum G2X Rooting, ROMs, and Hacks
    Last Post: 08-13-2014, 11:59 PM
  2. No mobile data connection
    By jmklei0 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 07-27-2012, 09:32 AM
  3. No mobile data connection on thunderbolt. Wife's incredible working fine.
    By RubberToRoad in forum Verizon HTC Thunderbolt
    Last Post: 08-06-2011, 01:38 AM
  4. Rooted w No USB Data Connection
    By bmiller001 in forum Verizon HTC Thunderbolt
    Last Post: 06-28-2011, 12:06 AM
  5. Mobile data connection not working
    By alear in forum Verizon Droid Incredible
    Last Post: 04-29-2010, 01:13 PM
