1. droidntn's Avatar
    Why would someone want this Spark over just simply getting a new battery and taking it along and swapping it out?
    ZAGGsparq | Portable Chargers For Tablets, Smartphones & USB Devices | ZAGG
    Has to be something I'm missing.
    06-19-2013 05:08 AM
  2. droidntn's Avatar
    I'm replying to this because now that I've seen that I'll have a need to get an additional power source because my son is in band and we make plenty of road trips. (me band daddy). So on those trips, a lot of bus time spent listening to music/surfing. My Maxx would even get a little low during a long trip.
    It just looks so obviously big and unhandy, I wondered if anyone was using it instead of just buying an extra battery.
    06-21-2013 05:52 PM
  3. seaham358's Avatar
    I own a different external battery and have it because for me its easier to plug it into that then taking my otterbox case off and changing the battery. Its what works for you is what you need to get. The larger external batteries can also be used to charge ipad and other tablets and cell phones. If you use a back up battery then it is only good for that phone. I have multiple items that can be charged with my external battery pack at the same time. Again its what you like..
    06-21-2013 07:36 PM
  4. droidntn's Avatar
    Excellent. See, these are my thoughts. What battery pack do you own?
    06-21-2013 07:47 PM
  5. seaham358's Avatar
    Just got the RAVPower RP-PB09 7800mAh Portable External Backup Battery Pack Charger on Amazon.
    I have used other smaller ones in the past and went for a bigger one to be able to power tablets and multiple phone charges.
    Smaller ones I have still have there place because they are smaller and easy to carry in pocket.
    06-21-2013 08:02 PM
  6. ibcop's Avatar
    06-21-2013 08:09 PM
  7. droidntn's Avatar
    I like that one cause it has a cord included. HOw many charges you get out of it for you S4?
    06-21-2013 08:18 PM
  8. geekymcfly's Avatar
    Why not go for the zerolemon
    06-21-2013 08:46 PM
  9. ibcop's Avatar
    It depends how far I let it run down. I typically will go to 10 percent left before I charge so this charger allows a full recharge with a bit left over.
    You can top it off, so to speak.
    06-21-2013 08:50 PM
  10. ihbsbA's Avatar
    I've had three of these and the cord that is built in to the device had stopped working in about two weeks. You can get close to two full charges but it's slow - I recommend the Akker brand (or Aker?) - much faster and the cord hasn't stopped working...
    Sent from my Galaxy S3 using Tapatalk.
    06-21-2013 09:00 PM
  11. droidntn's Avatar
    06-22-2013 02:23 PM
  12. ihbsbA's Avatar
    That's the one, yep. I have only had it a few days so I can't speak on how long it holds a charge but I believe the reviews said it was solid in that area. Tomorrow I will test the time it takes, but it was much faster than the Powergen - I charge at about 30% and was able to get two phones back to 100% on one charge. I've had several of these little power packs and this one has been :thumbup:the best.
    06-22-2013 10:30 PM
  1. Extra batteries or power packs
    By Getbusylivin in forum AT&T Inspire 4G
    Last Post: 08-04-2012, 11:24 PM
  2. HTC Hero extra battery case?
    By Verdes8891 in forum HTC Hero
    Last Post: 08-02-2010, 06:36 PM
  3. desktop dock with extra battery compartment??
    By wase4711 in forum EVO Accessories
    Last Post: 07-14-2010, 03:40 PM
  4. 2nd battery or larger battery?
    By crazy_vag in forum HTC EVO 4G
    Last Post: 06-22-2010, 08:29 AM
  5. Replies: 18
    Last Post: 05-27-2010, 10:41 PM
