It's ok, not a revelation, but I'd rather have it than not. I find for no apparent reasons sometimes it disappears even though enabled in the toolbar. (I just open the drop down bar and disable it, re-enable it..)
But other than that occasional glitch, I find it useful when I need it, mostly for adjusting Power Amp when I am reading an ebook on Kindle or Cool Reader. I pull out Multi-Window, load Pamp, change playlists, back out easily. It makes that process easier without having to go to some other screen to load P-amp, Messaging sometimes is helpful.
The real problem with the feature is that not enough programs support it. It has "internet" available for support. It would be nice if it had "Firefox," which is actually what I use. It has "mail" available, but not "Gmail" which is what I use. So mostly I use it for P-amp. Other things I might use it for are mostly not supported.
I find for no apparent reasons sometimes it disappears even though enabled in the toolbar..
It's useful if you're trying to do something on your phone like browse facebook or twitter and you're having an ongoing text message conversation. That way you don't have to be constantly switching back and forth.
This is the main reason why I dont use it or rely on it anymore. I had Google maps and gmail set, when i went to go use those apps real quickly....the sidebar was gone and i found myself spending too much time "fixing" it to reappear. Either theres a secret setting or button we push that makes it disappear, or just a buggy samsung gimmick
You don't have Gmail? ...I have Gmail on my multiwindow menu (I haven't installed any 3rd party "enhancement" apps either)
Holding the back button down for few seconds will enable/disable multi-window...that's probably what happens.
It's actually pretty useful for listening to music on youtube while doing other stuff. But other than that, yeah it's not THAT useful anymore...
I use it every night i usually leave netflix running at work and use it for text msgs so I wont have to restart the netflix app
