1. Zman1001's Avatar
    Hello all,
    I am trying to sync E-Wallet with my new S4 and am having a problem getting E-Wallet to recognize the S4 when connected to USB.
    I have synced this many other times with my two previous devices (Droid X and RAZR MAXX) without problem, but when I connect the S4 to the USB cable and computer, it only gives me two options - MTP / PTP, but not storage device.
    Any thoughts on how I get this to work. I am also going to send a note to the developer, but figured I would post here in case someone else has run into this before.
    Thanks
    Doug
    06-26-2013 03:02 PM
  2. paintdrinkingpete's Avatar
    Hello all,
    Thanks
    Doug
    The S4, along with pretty much all JellyBean devices, only support MTP/PTP. Mass storage mode is no longer supported.
    06-26-2013 03:33 PM
  3. Zman1001's Avatar
    Thank you. That just goes to show you how some changes go unnoticed once you have something set up before a new os update comes out.
    06-26-2013 06:49 PM
  1. S4 Active and audio volume/quality?
    By Mangan in forum Samsung Galaxy S4 Active
    Last Post: 03-24-2014, 10:21 PM
  2. Features Missing from S4 Active
    By Axis32 in forum Samsung Galaxy S4 Active
    Last Post: 02-21-2014, 10:20 PM
  3. Galaxy S4 Issues
    By mannyvigi1985 in forum Verizon Samsung Galaxy S4
    Last Post: 07-21-2013, 01:18 PM
  4. Is the S4 Active REALLY waterproof?
    By striders in forum Samsung Galaxy S4 Active
    Last Post: 07-03-2013, 03:16 PM
  5. Replies: 0
    Last Post: 06-26-2013, 12:48 PM
