1. gazza1591's Avatar
    Hi all
    My battery life is not good at all it can be on 100 percent in morning like it was 35 mind a go all I have done is look on Facebook and the net for about 20 mind and it's all ready on 81 percent u have used wifi to look at these aswell
    Also when I go into settings and look t battery the screen is taking up 43 percent and the android os is taking up 42 percent is this right? I have cleared all my cathe and still the same
    Any ideas?
    06-27-2013 11:32 PM
  2. gazza1591's Avatar
    Anyone
    06-28-2013 04:28 AM
  3. Christopher Matthews Jr's Avatar
    The only thing I can say, is dim the brightness, set the screen timeout to the shortest possible, etc..
    Are you rooted?
    Tapatalked from my Nexus 10
    06-28-2013 04:31 AM
  4. Marck527's Avatar
    Try juice defender Bro.. Works a treat for me
    Sent from my Samsung Galaxy S4 GT-I9500
    06-28-2013 04:34 AM
  5. gazza1591's Avatar
    Are you rooted?
    What you mean rooted?
    It's not to much the screen brightness it was the android os that seems heigh to me?
    06-28-2013 09:47 AM
  6. JamesBramble's Avatar
    Try turning of the Location Services. I've discovered that uses a lot of Battery power.
    Take a look at my thread
    http://forums.androidcentral.com/sam...-usage-up.html
    06-28-2013 10:57 AM
  7. nickgalaxys4's Avatar
    Turn off GPS and mobile data and yes screen also and close out the apps.
    06-28-2013 10:08 PM
  1. Air Gestures not working at all
    By Nguyenning in forum Samsung Galaxy S4
    Last Post: 04-12-2016, 05:28 AM
  2. Question about 5000 mAh USB external battery pack
    By Hydraulic Jack in forum HTC One M7
    Last Post: 08-08-2013, 07:44 PM
  3. Galaxy S3 does not support special characters in passwords?
    By Takashi Alekseev in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 06-28-2013, 07:49 AM
  4. Bluetooth does not work well with WiFi Calls
    By bardiferous in forum T-Mobile Galaxy S II
    Last Post: 06-27-2013, 05:29 PM
  5. Messed up battery
    By Silver15 in forum T-Mobile HTC Sensation
    Last Post: 06-27-2013, 02:25 PM
