Galaxy S4 Lock Screen Clock Lag
CurryGuy123
3
I got the S4 a week ago and have noticed that when I wake up the phone, it takes a second for the clock to change to the correct time. Say I lock the screen at 11:30 and then try to unlock at 12:00, the lock screen says 11:30 for a second before changing to 12:00.
Does anyone else have this issue and know if there is a fix? Or is there another thread about this already?
Thanks!
rsmurphy
8
Exact same problem with me, I got my S4 only two days ago. It is a bit annoying and I have done some digging but cannot seem to find a solution either.
garublador
1,135
Minimalistic Text does that for me, too. DashClock reports the correct time, though. I'd recommend it, anyway for the extra customization.
Sent from my SCH-I545 using AC Forums mobile app
singjai
86
It might be a problem with Samsung phones in general. Before the S4, I had the Samsung Brightside and it would do the same but lag way worse. My GS4 does that as well. Not sure about the other ones like The Note or S3
planoman
3,605
94
Do you know if its a problem with the phone using a lot of RAM just to wake up or is it a glitch in the OS?
I was talking about me personally... The clock is a widet I believe, and it need sto refresh. If it ran the entire time it would affect your battery. Does it really bother you?
JamesBramble
47
I've noticed the clock too coming out of the locked screen. It is quite annoying.
Maybe it is a bug on the S4's but I can live with it ;-)
Posted via my Samsung Galaxy S4
truthteller10
Banned
Dec 20, 2011
464
27
Nothing you can do about it my friend. This has been a problem that Samsung has failed to fix in all iterations since GS2..Lag is there to stay in the galaxy line.
planoman
3,605
94
I tend to click in and out of the lock screen quickly to check the time so it did at first, but it being a widget causing lag makes sense. But I'll try DashClock
Thanks!
Put the clock on your lock screen I see the the time as soon as I hit the home button. There is no delay. Maybe I am not sure where you are seeing the delay.
neiljay6
221
8
Ain't nothing to do with TW lag in this instance i don't think. The the stock clock is just slow to update. Luckily there are tons of other clocks to choose from in the play store that don't show any lag what so ever.
Jul 1, 2013
10
Thanks!
Same here, just ignore it.
MAK85
17
I have this issue as well with my Verizon Galaxy S4. I compared to other S4 users and they also experience this lag with stock lock-screen Clock. It is very annoying and has confused me a few times when I check the time quickly. Also interesting to note I compared this issue with 2 Galaxy S3 users (both on Verizon) and they do NOT have this issue. Will try dashclock
alimarie1331
4
I had the S3 for a year and this never happened. I got the S4 before it actually hit the shelves and this has just started happening in the last month for me. My husband still has the G3 and it doesn't happen to him. I've had exclusively Samsung phones since 2000 (except for a month with the awful Razr back in the day, and the iphone 4 for a year) and never had this issue. I'm on AT&T--is this an AT&T issue or are those of you also experiencing this on different carriers?
neel69
Active member
Nov 19, 2012
28
I use the S view case and on opening the flap, it directly goes to the lockscreen showing the clock which shows no lag.
Thanks!
jeffreii
CrackBerry Convert
Apr 20, 2012
798
53
I also did not have this issue on my S3...new problem with the S4. The last phone I experienced this on prior was my Blackberry Torch 9800. I hate turning on my phone just to see the time, then having to wait for it to update. I need to take a minute and try the Dashclock widget instead.
jeffreii
CrackBerry Convert
Apr 20, 2012
798
53
Loving Dashclock. Seems to have completely solved the clock lag issue. It's typically updated already when I turn the screen on...once I saw it update the instant the screen came on...so pretty damn good. And it's free, fairly customizable, and looks much better than stock. Thanks!
Adam Goodison
24
I noticed the lag issue about a month ago. Then downloaded dash clock, it's such a good app. Have you looked at the extensions you can add to it? You might find some useful ones
Nanran21
