Hi i have been using my s4 for 2 days now. Attempted to restart it last night.fell asleep and woke up to find it stuck on the Samsung logo screen that glows blue...what do I do???:'(
I have some problem after installing several different Roms. I flash the ROM and it's fine boots in no problem. Then after the second boot it gets frozen at the logo screen.
Thanks, it worked! To those facing the same problem, it still took a couple of minutes of Samsung logo flashing after this, only then did it finish booting.pull your battery out then insert, boot into recovery volume up + home + power, wipe date, wipe cache, reboot
it will work
can anybody help.my s4 is stuck on a screen saying "A custom OS can cause critical problems in phone and installed apps,If you want to download custom OS press the volume up key,otherwise press the down key" the thing is my "down " key is broken,even when I press the " up" key nothing happens.
- - - Updated - - -
I did what you told me to do but I got stuck on the same screen. I was trying to unroot using odin and this happened after the blue android. I have a i337m canadian gs4
it will work
