1. smoothrunnings's Avatar
    Hello,
    I am looking at buying an unlocked S4 and want to know what are the differences between the i337 and M919 models?
    I am currently with Virgin Mobile Canada.
    Thanks
    07-03-2013 06:52 AM
  2. veggie59's Avatar
    Hello,
    Thanks
    I have the M919....it is a Tmobile phone, not sure of the other one.
    07-03-2013 09:20 AM
  3. Joe_Perone's Avatar
    I337 is the AT&T variant, while I337M is the Canadian (Virgin, Rogers, Bell, etc.) variant.
    07-03-2013 11:46 AM
  4. Frank0072's Avatar
    The differences are the frequencies that the phones use. I'm in the same situation as you and am considering the T-mobile version of ths Samsung Galaxy s4(M919). From what I understand most versions of the I337's are software handicapped so that they are more restricted to using only the GSM frequencies. They can be rooted and the roms modified though with a T-mobile rom, if I understand correctly, to allow it to receive the AWS frequencies that the M919's use (also known as LTE band 4 AWS 1700/2100Mhz). T-mobile uses this as one of their frequencies, but this the main one for Wind Mobile and Mobilicity. The M919's that you can buy from Wind & Mobilicity can work on the big carriers GSM frequencies, but are either hardware or software handicapped so that they might not be able to take advantage of the high speed data frequency used for LTE (2600Mhz or LTE band 7). They would be able to use the big providers main voice and data frequencies up to 3G (850Mhz & 1900Mhz). This is why I will probably be seeking out a T-mobile version of the M919 which is unlocked to receive all of these frequencies from what I understand. That way if you start using Wind or Mobilicity and then move to a city that doesn't have their coverage, you could switch to any of the other providers and be able to receive the high-speed data signal (LTE or 2600Mhz) as well, not just the regular voice and data frequencies (850 & 1900Mhz).
    07-13-2013 06:49 PM
  1. I can text and call, but cannot use mobile data. Help!
    By Robert Garcia 10 in forum AT&T Samsung Galaxy S4
    Last Post: 07-10-2013, 11:01 PM
  2. Unable to Connect to WhatsApp and Viber from Mobile Network
    By C Teja in forum Samsung Galaxy SIII I9300
    Last Post: 07-09-2013, 09:16 AM
  3. Replies: 0
    Last Post: 07-02-2013, 05:00 PM
  4. droid maxx and download text pictures
    By st9966 in forum General Help and How To
    Last Post: 07-02-2013, 03:46 PM
  5. Scrren and settings problems with my HTC one. Help!
    By nalbagli in forum HTC One M7
    Last Post: 07-02-2013, 12:27 PM
