1. bm_99's Avatar
    People im looking to buy a 64 gb mem card for the s4 but would a Micro SD XC type work or just a micro sd?
    Also should i be wary when buying from ebay or just get it from amazon for a couple quid more??
    cheers, all
    07-03-2013 09:16 AM
  2. meyerweb#CB's Avatar
    I would be wary of buying from ebay unless its from a major reseller who's name you know and trust.
    SD XC will work, but with any 64 GB card you may need to reformat the card as FAT32, instead of exFAT. The Galaxy S3 does not support exFAT very well, and has lots of file corruption problems when used with an exFAT formatted card. I'm not certain if the S4 has the same issue, but think I saw a post here reporting the problem.
    See: http://forums.androidcentral.com/sam...dxc-fat32.html
    07-03-2013 10:29 AM
  1. SD Card Not Recognized
    By Muhnamana in forum Verizon Samsung Galaxy S4
    Last Post: 11-21-2014, 02:20 PM
  2. MicroSD card reliability
    By RenoD2010 in forum Accessories
    Last Post: 07-03-2013, 12:51 PM
  3. HELP -Water Damage
    By Cee922 in forum Samsung Galaxy Note 10.1
    Last Post: 07-03-2013, 10:20 AM
  4. HELP - Water Damage
    By Cee922 in forum Samsung Galaxy Tab 7.0 Plus
    Last Post: 07-03-2013, 08:55 AM
  5. Please help -- Phone won't stay on with unless I remove sd card
    By Cali Clark in forum Verizon Fascinate
    Last Post: 07-03-2013, 07:41 AM
