1. bm_99's Avatar
    People just wondering if theres a way to adjust the volume settings from the lockscreen or a way to make the phone silent or loud just from thr lockscreen like on an iphone with the button on the side.
    As i found this to be very easy to switch between loud and silent modes before going into meetings etc...
    Cheers
    07-04-2013 03:16 AM
  2. erasat's Avatar
    Cheers
    I don't know yours but my AT&T S4 just have the regular Sound Notification in the Notification Bar that you can easily bring down while your Phone is locked and switch between Sound/Vibrate/Mute, that's how I do it all the time.
    07-04-2013 08:42 AM
  3. nickgalaxys4's Avatar
    Cheers
    If you hold the power button you can put the phone on silent
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    07-04-2013 10:04 AM
  4. tytlyf's Avatar
    On the lock screen you have to pull down the notification bar, then press the sound key on side of phone to adjust. You can also hit the 'tool' icon on the right side of the volume slider bar when it's up to pull up the 4 different volume sliders.
    07-04-2013 10:24 AM
  5. ihbsbA's Avatar
    THIS is THE fastest way - you just have to get in the habit. Hold power button, select mute/vibrate /sound.
    Sent from my Sprint GS4 using Tapatalk
    Formerly "Evo_girl"
    07-04-2013 11:16 AM
  1. Not receiving texts from certain people (Verizon Galaxy S4)
    By tylerherwig in forum Verizon Samsung Galaxy S4
    Last Post: 11-10-2015, 05:08 PM
  2. Can I pin music from Google Music to the SD card?
    By Surfing32 in forum Samsung Galaxy S4
    Last Post: 07-25-2014, 10:49 AM
  3. Replies: 9
    Last Post: 07-13-2013, 12:57 AM
  4. Switching from Iphone 4s to 32GB Galaxy S4 - welcome all tips/apps/etc.
    By Kris Inman in forum Verizon Samsung Galaxy S4
    Last Post: 07-06-2013, 11:07 PM
  5. question about syncing music from itunes
    By KBlack2595 in forum Verizon Galaxy Note 2
    Last Post: 07-05-2013, 08:06 AM
