1. GK3K's Avatar
    I've had my S4 for about a month and have noticed during the past week, the phone no longer chargers to 100%. It slowly drains until completely dead even though the thunderbolt is visible indicating it's charging. I've been using the OEM S4 charging MicroUSB cable and charger since day one. I tried my S3's MicroUSB cable without any luck with the same results. The MicroUSB connection seems nice and solid.
    I've had to use an Anker wall charger to charge extra batteries to get by. My one month return window with Amazon just ended, so I can't exchange it.
    Any ideas? Thanks!
    07-05-2013 03:58 PM
  2. anon6016904's Avatar
    Have you checked the battery's temperature while plugged-in?
    mty mx
    07-05-2013 04:01 PM
  3. vasekvi's Avatar
    Have you checked the charge rates when it gets above 90%?
    Sent from my AT&T Samsung Galaxy S4 using Tapatalk II
    07-05-2013 04:10 PM
  4. skipatrol's Avatar
    Forgive me if this is a dumb question but why can't you exchange it? It has a 1 year warranty on it through your carreir does it not?
    07-05-2013 04:32 PM
  5. GK3K's Avatar
    mty mx
    Yes. It's in the 80-90 range.
    07-05-2013 11:41 PM
  6. GK3K's Avatar
    Using one of the battery monitoring apps? No. What am I looking for?
    skipatrol: I do have total equipment protection on the device from Sprint. You are correct though -- there is a 1 year warranty. Problem is, I risk getting a refurbished unit if I have Sprint replace it.
    07-05-2013 11:43 PM
  7. GK3K's Avatar
    Here is a perfect example. I took the OEM battery that was fully charged on a Anker wall charger and popped it into the phone. When I turned on the phone it was at 100%. I plugged the OEM charger in and started playing around with the phone just for a few minutes (looked at pictures, texted, etc) and it dropped by 1% and continues to drop as I type this message.
    07-05-2013 11:52 PM
  8. anon(6174973)'s Avatar
    I think your micro usb port has problems
    Sent from my GT-I9505 using Tapatalk 4 Beta
    07-05-2013 11:57 PM
  9. YoungSpade8's Avatar
    The USB out on a computer is NOT strong enough to power the phone while it is being used.
    If you use it lightly, you will slowly charge the phone, but if you play a game or use it extensive you'll lose battery power. Computer USB outs are in the 500-900ma range.
    The wall charger provided outputs at 2a. Use that. I realized this issue this morning and after using the supplied cable and supplied wall charger, I'm getting rapid charging even while heavily using the phone.
    07-06-2013 02:20 PM
  10. anon(6174973)'s Avatar
    Oh, were you charging your phone through your computer and using it at the same time? If yes, then try to use the wall charger as it charges faster.
    07-06-2013 03:05 PM
  11. sameer17dp's Avatar
    Try varying the performance parameters in the setting.
    Worked for me when i changed it to "powersaver"
    12-08-2013 04:21 AM
  1. Replies: 7
    Last Post: 09-08-2013, 06:16 PM
  2. Replies: 23
    Last Post: 07-11-2013, 05:53 PM
  3. Replies: 1
    Last Post: 07-05-2013, 08:00 PM
  4. is it possible to transfer video files between my Note 2 and S4 via NFC?
    By Kiersten_Kress in forum Verizon Samsung Galaxy S4
    Last Post: 07-05-2013, 03:49 PM
