1. acsurfer's Avatar
    Is there any gps function/app that uses handphone data and do not require use of gps satellite?
    I need it so that when I reach places that I cannot connect to gps satellite, I can use the handphone data plan for gps.
    Thanks
    S4
    07-05-2013 09:17 PM
  2. srkmagnus's Avatar
    In the location settings you enable location based on Mobile Network. It won't be accurate as GPS because it relies on mobile towers to triangulate your location.
    acsurfer likes this.
    07-05-2013 09:29 PM
  3. acsurfer's Avatar
    Where is the location settings that you mentioned? I cannot find it in my S4.
    Does it mean that after you enable location based on Mobile Network, all the GPS function will use the location based on Mobile Network? Do I need to go to the app to change settings or whatever? For example if I am using Sygic app or Google maps.
    07-05-2013 10:10 PM
  4. srkmagnus's Avatar
    The setting should be with the GPS setting in the devices system settings. I don't have the S4 to tell you where exactly the setting is located. It should be: menu > system settings > location access
    Let me know if you need further assistance, we're here to help.
    zkSharks and acsurfer like this.
    07-05-2013 10:52 PM
  5. zkSharks's Avatar
    I'm going to throw this over to the S4 forum so that you might get some quick help from another S4 owner. Not that srkmagnus's responses go unnoticed.
    07-05-2013 11:01 PM
  6. SERBDVB's Avatar
    i use NAVIGON with data off , and have no problems best gps app ever bit of money but thx to google search is free hahaha
    07-05-2013 11:16 PM
  7. jokout1's Avatar
    settings>more>location services>Use wireless networks (check the box) and make sure "use GPS satellites" is unchecked.
    Cheers
    srkmagnus, zkSharks and acsurfer like this.
    07-05-2013 11:24 PM
  8. srkmagnus's Avatar
    Thanks, Patrick. Looks like we got the appropriate response fairly quick. Thank, Jokout1!
    07-06-2013 12:47 AM
  9. acsurfer's Avatar
    If I have ticked the "use GPS satellites" the phone will use GPS satellites. When the phone reaches a place where GPS satellites cannot be connected, will the phone automatically use mobile towers to triangulate my location?
    07-06-2013 08:08 AM
  1. Go Sms Pro will not send MMS on 4g LTE... Why Please help
    By Killa1065 in forum General Help and How To
    Last Post: 06-01-2016, 06:44 PM
  2. Seems To Be Overheating And Not Able To Hold A Charge
    By maybachgurl in forum Google Nexus 10 Tablet
    Last Post: 07-11-2013, 12:44 AM
  3. Slings, Grips, Cases and Rings
    By Niall Devlin in forum HTC One M7
    Last Post: 07-10-2013, 05:15 AM
  4. What is Motocare?
    By A895 in forum Droid RAZR M
    Last Post: 07-05-2013, 03:51 PM
  5. How To root HTC EVO 4G running Android 2.3.3 without wiping data
    By Andy Denver in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-05-2013, 03:12 PM
