1. S4user's Avatar
    when i work on wifi in my room (1-2 lines,bad connection) my battery get of quickly then when i work on 3G..
    its can be???
    i mean i have good 3g connection then when i turn on wifi ....
    i glad for any help..
    Tom
    07-06-2013 11:08 AM
  2. DS1331's Avatar
    WiFi will eat your battery up quicker then 3g. And also the 3g signal doesn't matter if you are connected to WiFi
    Sent from my HTC One using AC Forums mobile app
    07-06-2013 11:11 AM
  3. Wilbur's Avatar
    And 3G will use up your DATA amount where WiFi won't. Since the OP is home using WiFi plug in the charger while using the phone ... and save your DATA when no WiFi is available.
    07-06-2013 12:09 PM
  4. Soundtrack to Chaos's Avatar
    I don't agree with this, my phone always loses more battery when on 3g than it does on 4g or wifi.
    Sent from my Sprint Samsung Galaxy s3 running Liquid Smooth v2.7 with a 7000mah extended battery powered by ZeroLemon... Because I'm not a chick, a guy with dainty hands or an HTC one user
    07-06-2013 12:22 PM
  5. DS1331's Avatar
    Depends on the signal strength if you have 1 or 2 bars of 3g and it keeps trying to find signal or it keeps fluctuating then yes your battery might die faster then if you're connected to wifi
    07-06-2013 12:25 PM
  6. DS1331's Avatar
    Any other thoughts I'm just speaking on my experiences
    07-06-2013 12:25 PM
  7. S4user's Avatar
    my 3g singel very good and wifi bad singel.. so its can cause ?
    this phone amazing.. anyway i looked today the phone was 84% after 10-20 min its down to 78%
    how its can be? the battery lie to me? LOL
    07-06-2013 01:19 PM
  8. DS1331's Avatar
    You should download battery guru or any battery monitor app because it will tell you what's using so much of your battery
    07-06-2013 01:41 PM
  9. YoungSpade8's Avatar
    What are you actually doing on the phone? Personally, when I'm on a WiFi connection around my house , I'm doing heavy browsing along with HD video from YouTube and things like that.
    When I'm out, most of the time it's light browsing or reading with pocket.
    So pay attention to what you're doing. The fact of you downloading pages faster and therefore visiting more sites is more taxing on the CPU too.
    DS1331 likes this.
    07-06-2013 01:56 PM
  10. S4user's Avatar
    i think my heavy work on the phone its whatsapp most of the day..
    i download some battery monitor and i think i'm just paranoid
    now i have 60% - 9 hours work.. preety good i think..no? (no music,no WIFI,only whatsapp and little browsing)
    07-06-2013 03:03 PM
  11. nickgalaxys4's Avatar
    Hi if you are on wifi and have 3G/4G won't matter. I believe that 3G/4G does kill battery more than wifi.
    07-06-2013 03:41 PM
  12. Soundtrack to Chaos's Avatar
    When I'm on 3g I rarely get more than 3 bars. When I'm on 4g I usually have either 1 or all bars. And when I'm oh wifi, i usually have between 1-3
    07-06-2013 05:49 PM
  13. S4user's Avatar
    hey guys,
    don't know what to say.. when i'm on 3g i have all the bars .. and when i'm on wifi i have 1-2 lines... and i think the phone work hard to get this signal.. its can be the reason that my battery end so fast on wifi? (its happen only in my room..)
    thanks for help
    have a nice week
    tom
    07-06-2013 10:58 PM
  1. Galaxy S4's general stability vs its competitors
    By GMasonDragonDad in forum Verizon Samsung Galaxy S4
    Last Post: 07-09-2013, 10:43 PM
  2. Unable to maintain wireless connectivity to Droid 3
    By hickydoo in forum Motorola Droid 3
    Last Post: 07-07-2013, 11:00 PM
  3. Push email notifications on Wifi
    By kostnkost in forum HTC One M7
    Last Post: 07-06-2013, 10:38 PM
  4. WiFi won't come on
    By ajbrad71 in forum HTC One M7
    Last Post: 07-06-2013, 08:35 AM
  5. WI-FI won't stay connected!
    By TjChocolate in forum Verizon Galaxy Note 2
    Last Post: 07-05-2013, 10:29 PM
