1. samthesam's Avatar
    When I try to call some one a white screen appears for a while and the same calling page opens.plz some one help me with this problem.
    07-06-2013 12:26 PM
  2. BobR1908's Avatar
    My recommendation would be to do a soft reset on the phone, if that does not fix the issue try a factory reset next.
    07-06-2013 12:52 PM
  3. nickgalaxys4's Avatar
    Hi and welcome to forums.. Yes I would also try reseting then factory and if it doesn't fix then bring it back to the store and see what they say.
    07-06-2013 02:47 PM
  4. Abdul Alhaidary's Avatar
    I just had the same program and managed to fix it. The thing is ur phone gets confused to which program it should make the call with (viber,tango, line etc...). Just go to settings - application manager - all - reset app preferences - ok
    All fixed !!!!! And no data lost. Hope u didn't format ur phone !!!
    07-14-2013 09:58 AM
  1. How do I turn my home screen into a lock screen too?
    By arism74 in forum Samsung Galaxy SIII I9300
    Last Post: 07-07-2013, 08:23 AM
  2. Does note 2 work with a charging pad?
    By ansa82 in forum Verizon Galaxy Note 2
    Last Post: 07-06-2013, 09:49 PM
  3. Replies: 5
    Last Post: 07-06-2013, 01:12 PM
  4. Custom Rom data problem on Go Phone
    By maegen117 in forum AT&T Galaxy S III
    Last Post: 07-06-2013, 12:17 PM
  5. Replies: 1
    Last Post: 07-06-2013, 12:09 PM
