1. Stephen Yelverton's Avatar
    Hi there. I'm brand new to the forum. Just got a Galaxy S4 last week...coming from an iPhone 5. So far I'm really liking it. One annoyance is that the phone does something strange when being used with my car's bt audio system. If I start a song then restart the car, the song starts over from the beginning. Although it's not a deal killer, it's really annoying as my phone is my primary means of music in my car. My iPhone would "remember" where the song left off and resume from that point the next time I started the car. Is that something that the GS4 is unable to do? Or could it be something weird between my car's audio system and the GS4?
    Any input would be great! Thanks!
    07-07-2013 12:08 AM
  2. tre flip's Avatar
    if your using the stock audio player go into settings from the music app. you should find a setting that will stop that and will just continue from when you left off. hope this helps. you can always google your problem and youll find an answer. good luck
    07-07-2013 01:38 AM
  3. Stephen Yelverton's Avatar
    Thanks I'll take a look at that. I did google this first...just couldn't find anything.
    07-07-2013 10:27 AM
  4. geoffropuff's Avatar
    did you ever find a solution to this problem? i'm having the same issue, which wouldn't be that big a deal if i was just listening to music. however, having to find your exact spot in a 2 hour podcast every time you get in and out of the car is quite annoying...
    08-21-2013 11:59 AM
  1. Thoughts after I rooted my Nexus 4 for the first time
    By devchaube15 in forum Google Nexus 4
    Last Post: 07-07-2013, 05:42 PM
  2. Samsung S4 Best Selling Android in History
    By Nreeldeep in forum Samsung Galaxy S4
    Last Post: 07-06-2013, 11:57 PM
  3. Nexus 10 16GB with Extras
    By Stein357 in forum Marketplace Archive
    Last Post: 07-06-2013, 11:35 PM
