1. n92991's Avatar
    Please help me this is my first time buying a high-end smartphone
    , it the international version, gt-i9500 and its been a month and 2 weeks since i got it
    the first issue, sometimes the camera just get stuck, and the phone restarts
    one other time, i can hear others during a call but they cant hear me - i fixed this through factory reset
    some other time again, during a call, the call-ee can hear me and i cant hear them - solved this through factory reset too
    Now, a bigger problem smashed up,
    when i connect the s4 to my laptop, noting happens.
    Yes, the normal usb options does not come up the notification bar. I cant transfer any files to / from pc - s4
    Someone help me
    I just googled android forums,and here i am, registering an account just to hear out any comments that may help me
    07-08-2013 08:01 AM
  2. anon(6174973)'s Avatar
    Someone help me
    Seems like the phone firmware has problems.
    As for the USB part, have you tried putting the phone into USB Debugging mode?
    n92991 likes this.
    07-08-2013 08:16 AM
  3. n92991's Avatar
    usb debuging?
    nah just heard of it, so how is this ''usb debugging'' which you speak of done??
    07-08-2013 08:25 AM
  4. anon(6174973)'s Avatar
    usb debuging?
    Go to Settings > More > Developer Options > USB debugging
    07-08-2013 08:30 AM
  5. n92991's Avatar
    That didnt work my friend
    07-08-2013 08:35 AM
  6. Golfdriver97's Avatar
    Try downloading and installing Samsung drivers to your PC.
    Sent from a Carbon Galaxy S3.
    07-08-2013 08:38 AM
  7. anon(6174973)'s Avatar
    Won't your pc automatically install drivers as soon as you connect it?
    Sent from my HP Slate 7 using Tapatalk 4 Beta
    07-08-2013 08:48 AM
  8. n92991's Avatar
    Yh thats what should be happenin, But that aint happening now .... can anyone link me to a driver download?/?/
    07-08-2013 08:54 AM
  9. anon(6174973)'s Avatar
    Go into Samsung official website and go to the download center.
    07-08-2013 09:15 AM
  10. paintdrinkingpete's Avatar
    It should, yes. The GS4, as with almost all new Android phones running anything higher than ICS, use standardized MTP/PTP protocols for USB-to-computer connections, so the device should be picked up by windows computers without the need to install additional drivers (the drivers are generally only necessary if you're doing more advanced tasks over USB, such as accessing it via adb or fastboot or using ODIN to flash firmware). Having said that, it may not hurt to try.
    To the OP: when you plug in the device, does *anything* happen? Do you get the familiar "new device" audible notification chime? Does it show up in device manager? Do any error messages appear on screen? ...or just simply "nothing" happen?
    First thing I'd do is rule out an issue with the USB port by trying a different port on my PC...then I'd rule out an issue with the PC itself by trying to access my phone on a different computer to see if that works...
    07-08-2013 09:45 AM
  11. fantom305's Avatar
    Go to Samsung.com and download the USB drivers into your computer, that should fix the recognition problem.
    07-08-2013 11:06 PM
  12. anon(6174973)'s Avatar
    Depends on whether it's supported or not.
    07-09-2013 08:40 AM
  1. Help please! HTC One Car Dock - disabling docking sound!
    By Dominic Mehta in forum HTC One M7
    Last Post: 09-17-2013, 01:19 PM
  2. Initial rooting fail. Please help!
    By jus2sho in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 07-09-2013, 04:23 PM
  3. Samsung Galaxy S4 Teardown and Repair Service Video
    By Erkan Akkaya in forum Samsung Galaxy S4
    Last Post: 07-08-2013, 05:58 AM
  4. Wi-Fi and Mobile Data
    By kah22 in forum Samsung Galaxy S4
    Last Post: 07-08-2013, 04:38 AM
  5. Replies: 0
    Last Post: 07-08-2013, 02:50 AM
