1. nivekuil's Avatar
    The battery on my new s4 was at 40% or so when I went to sleep, and 12% when I woke up. BetterBatteryStats and Wakelock Detector report that it was in deep sleep >95% of the time, so why is this happening? I have most of the pre-installed bloatware disabled, and also have Easy Battery Saver installed. The phone was also on Power Saving mode with all options enabled.
    https://www.dropbox.com/s/m8tmzs99bk..._124341218.txt
    07-08-2013 02:51 PM
  2. anonymous495876038576's Avatar
    Was the phone on WiFi or cellular? Also were you roaming or in a bad coverage area?
    Sent from my XT881 using AC Forums mobile app
    07-08-2013 03:14 PM
  3. nivekuil's Avatar
    Wifi should have been disabled by Easy Battery Saver (it does so automatically after a period of non-use) and cellular was disabled. I did just notice that bluetooth is enabled, must have accidentally turned it on. Even so, should the battery drain be that severe?
    07-08-2013 03:25 PM
  4. ncreptile's Avatar
    I am also having battery issues.
    I have screen brightness at 30%, I have power saver on. I have air gesture, eye control, voice control all off. I do keep 4g on constantly but I am draining 10% per hour with LIGHT use.. And I tried new batterie s and those are doing it to.
    So what gives?
    Its so bad that when I plug usb into my laptop the phone actually still drains as it charges.. But far slower.
    07-08-2013 03:57 PM
  5. tytlyf's Avatar
    If you are using the phone while charging off a laptop then it will most likely drain slowly and not increase battery life depending on what you are doing.
    07-08-2013 08:37 PM
  6. tvouge's Avatar
    Was it a just out of the box new? Because I had pretty bad battery life the first day but it improved after syncing and dling all my apps. Has it gotten better?
    07-08-2013 09:22 PM
  1. Custom your photo for Galaxy S 4 Battery Cover by senppo
    By senppo in forum Samsung Galaxy S4
    Last Post: 09-03-2013, 09:43 AM
  2. Which Google service is running my battery down.
    By justmikey in forum Google Nexus 4
    Last Post: 08-04-2013, 02:54 PM
  3. brand new battery takes a while to work properly?
    By thewango in forum Google Nexus 4
    Last Post: 07-09-2013, 11:11 AM
  4. Battery Life
    By batman741 in forum HTC One M7
    Last Post: 07-09-2013, 01:35 AM
  5. Any extended battery life case
    By akizys37 in forum Samsung Galaxy S4
    Last Post: 07-08-2013, 10:12 AM
