1. Mysteriouskk's Avatar
    I have a galaxy s4 with a work phone number. Is there a way I can also add my personal # to it to send and receive texts and calls?
    07-09-2013 02:08 PM
  2. EvilMonkey's Avatar
    Hmmm...that's a tricky question. Is the personal number a mobile number or land line? If it's mobile do you have another phone that you're under a contract for?
    Hopefully someone with more experience will chime in, but my initial thought (without more information) is to set up Google Voice. You could either migrate the personal number to it, or forward calls to it. Then Google Voice on your phone will get calls and send texts through it (I think you need to use the Google Voice app to text though unless they've changed things).
    There might be other options, but that's what initially pops into my head. I think that will work.
    07-09-2013 05:15 PM
  1. No merge to Google option with Contacts
    By Scottydont87 in forum Samsung Galaxy S4
    Last Post: 01-09-2014, 06:33 AM
  2. Using international SIM cards?
    By bengalih in forum Droid RAZR MAXX HD
    Last Post: 07-10-2013, 11:29 AM
  3. VZ S4 Makes Sound When Shaken - Noise Like Loose Change
    By Zudnic in forum Samsung Galaxy S4
    Last Post: 07-09-2013, 01:36 PM
  4. Changed Screen Lock (Nightofpartying)and don't REMEBER CODE!!!!
    By keiva in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 07-09-2013, 01:01 PM
  5. S4 verizon aux cable issues
    By trongone1 in forum Verizon Samsung Galaxy S4
    Last Post: 07-09-2013, 12:47 PM
