1. KingofQueens89's Avatar
    First off, excuse me if this has been beaten to death. This is my first android device (galaxy s4), and I cant seem to choose a new wallpaper without it being cropped out. Is there an app or a way to resize the picture so that nothing is cropped out?
    07-10-2013 06:59 PM
  2. slackerjack's Avatar
    There are several apps that will let you select a wallpaper in full and not in the stupid assanine way implemented by Google (this crap started in honeycomb). I've always used "Wallpaper for Tablets" ( works fine on phones too) its technically a live wallpaper, but because you're setting a stagnant image doesn't suffer the battery drain that other live walls do! Has some neat extra features too like setting per home screen wallpaper!
    07-10-2013 07:23 PM
  3. KingofQueens89's Avatar
    I've downloaded the app and selected a image from my gallery, however, my wallpaper does not change. Is there a place to confirm or save the change?
    07-10-2013 07:51 PM
  4. SenseMonkey's Avatar
    Check out "Simple image wallpaper free". It lets you select full resolution pictures for wallpapers. First make sure to select the "Simple image wallpaper" in your Live wallpapers; then select the picture and bingo! :thumbup:
    From my Sammy Galaxy S4
    07-10-2013 08:12 PM
  1. S4: How to turn off vibrate for email notifications
    By tabs31 in forum Samsung Galaxy S4
    Last Post: 11-24-2014, 10:22 AM
  2. My camera lens is all scratched - Can his be fixed
    By deejayburnout in forum Samsung Galaxy S II
    Last Post: 07-31-2013, 04:46 PM
  3. Just bought a Galaxy S4.
    By rkeenan in forum Samsung Galaxy S4
    Last Post: 07-12-2013, 11:14 AM
  4. spen function help needed
    By Lisa Mclendon in forum Samsung Galaxy Note 10.1
    Last Post: 07-11-2013, 12:04 PM
  5. How to make notification bar transparent Verizon s4
    By jeffruby in forum Samsung Galaxy S4
    Last Post: 07-10-2013, 06:45 PM
