1. David Boyadjian's Avatar
    Hi guys, i use a 2gb sd card on my galaxy s4. I dont use much apps. I use the phone more for work purposes.. usually for appointments and browsing the web. The issue is that i felt the phone extremely overheating.. so i restarted it..(naturally) and when i went through the so little apps that i have.. i found out that Pou and Candy Crush were somewhat missing. Not rraly missing.. just a default icon of android and when i press on the icon it says that the application is not installed. I checked the storage in settings and found out that these two apps were installed on to my sd card. And now i cant move them back to my device memory neither can i access them... any ideas thx.
    07-14-2013 11:51 AM
  2. jrsharp70's Avatar
    Unmount SD card, throw SD card in trash, install apps, get SD card with 4 times the storage on amazon for $10. Use Samsung card just to be sure.
    07-14-2013 12:01 PM
  3. David Boyadjian's Avatar
    i could've donw that and not have posted this thread..Was looking more for a DIY reply to fix the card.. but thx anyways.
    07-14-2013 12:24 PM
  4. starbuckk's Avatar
    Was the card encrypted by chance? And was the reset a factory reset? If yes to both, its toast.
    You might try recovering the data on a pc.
    Sent from my SCH-I545 using Tapatalk 2
    07-15-2013 07:58 AM
  1. Moving apps to sd card help!!!
    By logan121691 in forum LG Optimus Elite
    Last Post: 02-23-2014, 10:39 AM
  2. Please help a newb! HTC Evo 4g LTE screen/power issue
    By cnballa7 in forum HTC EVO 4G LTE
    Last Post: 07-16-2013, 09:36 PM
  3. Howto workaround google now headset issue #36026
    By Ekman in forum Sony Xperia Series
    Last Post: 07-14-2013, 02:17 AM
  4. Using the G Pro & Sd Card
    By CarlosSpiceyW in forum LG Optimus G Pro
    Last Post: 07-13-2013, 08:16 PM
  5. having issues with restore
    By goddyunoh in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-13-2013, 05:57 PM
