When i'm on a call with my Galaxy S4 the screen goes off/blank and I have to press the home button. Does anybody know how I can keep the screen on the whole time during a call.
I really wish people would at least TRY going through their settings before asking a question like this
I understand you, but at the same time there are many people who aren't familiar with smartphones.
It doesn't hurt to help someone from time to time.
Sent From a Galaxy S4 Away
This. Some people don't know about the various menus so.. They ask here and we can help.
Sent from my Sprint HTC One using AC forums.
There is a difference between trying and not trying though. I came from Blackberry I had NO idea what to do with an Android, I simply went through menu to menu and figured it out.
Point is, it's obvious some people don't even TRY. That's my point.
I have worked with these settings extensively, and I still have the same question as the original poster had. So is there another way to keep your screen on outside this one setting?
I'd definitely check that. IIRC, there was a bug fix for the screen not always coming on when you're on a call.Which carrier do you have and do you have the latest updates?
Have you done a factory reset?
It's supposed to happen automatically. There may be a little bit of a delay (maybe a second or two) while the proximity sensor reacts.is there a setting for galaxy s4 that will make the phone light back up when you move it away from your ear when it goes blank during a call?
