Hi all. Just now i tried flashing a Cwm recovery through mobile odin and now my s4 is unable to start. Must I use a computer to flash it?
Sent from my HP Slate 7 using Tapatalk 4 Beta
I would use the PC version of ODIN. reflash the stock recovery and start over. You are rooted, correct?
Sent from a SlimROM S3.
As long as your phone can be detected on the PC, I would absolutely use the PC version of ODIN.
Can you get into cwm recovery? If you can or the phone can get into download mode we can get you restored.
Sent from my SPH-D710 using Tapatalk 2
What model S4 do you have and can you link the cwm recovery?
Mobile ODIN isn't a bad thing. I used it all the time with my E4GT.Problem solved. I woke up this morning and hurriedly turn on my computer to flash the stock firmware so that I can unbrick the device. After it booted up, i immediately uninstalled the stupid mobile odin and i would only use cwm to install stuff.
Thank you all for your time
That may be true, but I have read more threads of mobile Odin creating problems as opposes to not.
