1. s4user1's Avatar
    Hi. The samsung pc kies shows that my s4 is updated , but i know that he has a very old software. I updated pc kies. But why it doesn't give me right firmware updates ? Did anyone have the same problem? Plz help.
    Sent from my GT-I9500 using AC Forums mobile app
    07-20-2013 06:59 PM
  2. s4user1's Avatar
    I know that i can install the new software manually via odin. But i want to know what is the problem with pc kies.
    07-20-2013 07:01 PM
  3. Wilbur's Avatar
    Kies was giving my (homebuilt) Windows 7 x64 desktop big problems. It seemed to be preventing the usb driver from allowing Windows Explorer to look at the phone and SD card. I had to keep re-installing the USB driver to get it to work properly. After uninstalling Kies I can transfer files with the phone hooked up via USB using Windows Explorer. Whew. Kies is a waste; Samsung's attempt to limit us to something like iTunes. No thanks.
    I did the latest Verizon GS4 update over the air taking about 15 minutes after several unsuccessful attempts with Kies freezing at 33% and then 66% of the install.
    07-20-2013 07:55 PM
  4. Hassan K. Malik's Avatar
    If your phones rooted, Kies will not detect it... U gonna have to manually download the firmware and flash it thru odin...
    Sent from my GT-I9500 (Hassan Khalid Malik) using Tapatalk 2
    07-22-2013 07:10 PM
  5. gollum18's Avatar
    Kies is janky garbage, just like Odin. Its basically the official version of Odin minus full power usage. If your going to flash anything use heimdall, its far better and is built from source, best of all it isn't leaked software.
    However if you're rooted, flashing a stock update will make you lose root. And it may even fail to flash, as your system will be detected as modified. Kies still uses your recovery to flash it, and the recovery checks for a completely stock system, if it finds anything out of place it will fail.
    Either use heimdall or Odin, or place the update on the root of your sdcard and flash it from recovery.
    Sent from my paranoid s3...
    07-22-2013 08:43 PM
  1. sdcard problems
    By markbehr in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-23-2013, 09:28 AM
  2. Replies: 3
    Last Post: 07-23-2013, 03:04 PM
  3. news problem
    By Alex Crisan in forum Samsung Galaxy SIII I9300
    Last Post: 07-20-2013, 04:45 PM
  4. Keyboard problems
    By annatter in forum Samsung Galaxy S4
    Last Post: 07-20-2013, 04:41 PM
  5. Replies: 0
    Last Post: 07-20-2013, 03:10 PM
