The phone could not resist the pool in this heat and went swimming for about 20 seconds. I got it out, yelled at it and told it to never do it again. Then I took the battery, Sim and SD card out and dried it. Finally, took it to a shop that disassembled it and cleaned the inside using an alcohol based solution. But the phone could not be be revived fully. It shows the boot up screen and then goes blank and vibrates a couple of times.
Now, if it is plugged in at the boot up time, it will boot up fine BUT the battery keeps showing 100% and will not go down at all. Also the capacitive buttons don't work. Rest everything works just fine.
Any suggestions on these two issues? I am thinking of getting a new battery and trying it. Don't need an extended battery just a replacement of OEM. Any links to that would be appreciated.
Any tips on the capacitive buttons? (Other than Button Saviour like apps)?
