Bluetooth Call Audio/Media Audio: Can ONLY select ONE option
When I connect to my Honda Hands Free Link (Pilot 2013), I can only have one option enabled. Unless I uncheck one, I cannot check the other. Anyone else have this issue? I would like to use my cars Bluetooth to playback Sirius XM and also answer phone calls. I am forced to choose only one.
In addition, I cannot use the car's USB cable because it says unsupported format. I gather that is from the fact Android no longer treats the device as a "mass storage" disk.
Edit: Issue resolved.
Re: Bluetooth Call Audio/Media Audio: Can ONLY select ONE option
I have the same issue with a Pioneer X940BT head unit... How'd you resolve it?
Originally Posted by
Michael Miles2 I have the same issue with a Pioneer X940BT head unit... How'd you resolve it?
I was doing it while away from my car. When you pair it and view it while in your car, it lets you select both.
Did you get yours to work? I have the same problem with my car connection, and I cant select media audio even when it is paired with my car.
