1. Millzey13's Avatar
    Hi Everyone,
    I came across a problem today with some of my albums splitting in the music store/music apps.
    I searched the web and there are many programs that can sort this for you but being new myself i found a way i thought was easiest for me.
    This was a little longer than maybe using a program but most of them were confusing if you haven't got the savy to use them
    I found that it was only a few songs/albums that this happened with but was most annoying,basically an album will split on your phone if some of the tags from the original up loader have not been entered correctly.
    in the first screen if you go into you music folder for the said file that is splitting your see that you have your lists for Album/artist/genre etc.
    in screen 2 if you right click on the bar there on you are able to list pretty much anything that would have a tag on it.
    screen 3 shows all these selected,once this is dont just scan through and anything that doesn't match up will probably be the issue as to why its splitting. Some things dont matter but the main ones ive come across are Genre-Album-Album artist-Artist and Album i.d.
    remember to delete the file first of your sd card or internal then copy the alternated one back over and every thing should be fine.
    Sorry if this is long winded or boring but i was over the moon when i finally got all my music to group.
    I did use winamp to try this but still had some issues and this being the longest route was still the most effective.
    Thank you
    Attached Thumbnails GUIDE. (Beginners)-screen1.png   GUIDE. (Beginners)-screen2.png   GUIDE. (Beginners)-screen3.png
    07-27-2013 09:23 AM
  2. Golfdriver97's Avatar
    Thanks for sharing.
    Signed, a Nexus 5, AC forums app, and Android L.
    07-24-2014 08:11 AM
  1. [Old version][Guide][Samsung] How to flash Stock ROM via ODIN
    By Golfdriver97 in forum Ambassador Guides, Tips & How-To's
    Last Post: 10-20-2015, 07:36 PM
  2. [Guide] How to use your Custom Recovery
    Last Post: 02-11-2015, 06:33 AM
  3. [Guide] [Tools] File Extracting programs
    Last Post: 12-10-2013, 10:43 AM
  4. [Guide] [Supplemental] How to flash in Custom Recovery (Clockwork Mod)
    Last Post: 09-30-2013, 08:11 AM
