1. Steve Swift's Avatar
    I'm in
    Settings > Display > Notification panel
    ... where it says:
    "You can customise which quick settings buttons appear at the top of the notification panel."
    I can? How? Nothing I've tried so far has had any effect.
    07-29-2013 02:48 AM
  2. Steve Swift's Avatar
    It's amazing how quickly you find your own answer after asking some questions!
    I don't think I can control which buttons are present, just the order they are presented. By default the first 5 in the list appear; you have to scroll to get to the rest.
    07-29-2013 02:54 AM
  3. tytlyf's Avatar
    That's correct. The icons can't be deleted, but can be rearranged. A trick is to use 2 fingers at the top to pull down the notification bar instead of one finger. That will show the whole list. Or you can hit the 'tool' icon in the notification panel to bring them all up.
    07-29-2013 11:25 AM
  4. Steve Swift's Avatar
    ... A trick is to use 2 fingers at the top to pull down the notification bar instead of one finger. That will show the whole list. Or you can hit the 'tool' icon in the notification panel to bring them all up.
    I come from the age where people would bite your head off for touching the display... I've bought myself a couple of those "stylus pens" with a rubbery false fingertip on the end, so I don't transfer grease from my fingers to the displays of my Galaxy Tab 10.1 and S4. This makes the two-fingered gestures something of a problem. I'll probably get there eventually, but in the meantime it's good to know about alternatives like your 'tool' icon in the notification panel.
    Thank you.
    07-29-2013 03:53 PM
  5. eli234's Avatar
    I have a problem with that because for some reason i don't have the option of sliding down two fingers.
    I have a samsung galaxy s3 4g
    Any suggestions?
    12-22-2013 09:50 AM
  6. danhartman26's Avatar
    I don't think the S3 has the two finger drag gesture available 😣
    Sent from my SCH-i545
    12-22-2013 01:24 PM
  7. bincy's Avatar
    the quick settings panel is not appearing sometimes when i pull from top to bottom..... i will get it only aftr restarting the device....any solution to solve dis issue?
    04-18-2014 02:08 AM
  1. Replies: 19
    Last Post: 11-04-2014, 10:23 PM
  2. What exactly are the new update features of 4.3?
    By popcan4u in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-29-2013, 04:31 PM
  3. Any apps stopped the working on your android mobile
    By Device Point in forum The Android Central Lounge
    Last Post: 07-29-2013, 01:45 AM
  4. pop the fruit 2 [Cute]
    By Estrellislia in forum Android Games
    Last Post: 07-29-2013, 01:24 AM
