1. Steve Swift's Avatar
    Is there a setting to prevent the display blanking when the USB cable is plugged in?
    This is akin to the display settings in the power control in Windows, where you set independent timeouts for "On Battery" and "Plugged in"
    07-29-2013 02:57 AM
  2. dd_terry's Avatar
    Steve,
    You can set the "Stay awake" option under the "Developer options"
    You turn on "Developer options" by going to settings -> More tab -> About device -> Tap the "Build number" 7 times. You'll then see Developer Options under the More tab.
    This way the screen stays on whenever it is plugged into the USB cable.
    Terry.
    msndrstood likes this.
    07-30-2013 07:47 PM
  1. Turn off Profanity Filter on Voice to Text?
    By Eclipse2K in forum Samsung Galaxy Note 2
    Last Post: 08-16-2016, 10:48 PM
  2. Replies: 19
    Last Post: 11-04-2014, 10:23 PM
  3. Voice-To-Text doesn't work well?
    By mattl2 in forum Samsung Galaxy S4
    Last Post: 08-01-2013, 08:02 PM
  4. How to print web page to PDF ? ? ?
    By ScottyG05 in forum Samsung Galaxy Note 10.1
    Last Post: 07-29-2013, 01:20 PM
  5. unable to tether at all
    By oleyota in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-29-2013, 12:05 AM
