1. Crinny's Avatar
    Hey, ive had my s4 for a dew weeks now and almost straight away had the 'Google Services' battery drain issue. Now I have a new problem, this time its Android Services taking up over half of my battery life. Can any one shed some light on what might be causing it?
    Thanks
    07-29-2013 01:43 PM
  2. Almeuit's Avatar
    As with most batter threads... Screen shots first help. Of your battery.. Screen on time.
    After that get better battery stats to figure out what is causing this... Or wakelock detector.
    Sent from my T-Mobile HTC One using AC Forums.
    07-29-2013 01:46 PM
  3. Crinny's Avatar
    Sorry man here;
    Attached Thumbnails Battery drain that isn't Google Services!-screenshot_2013-07-29-18-49-34.jpg   Battery drain that isn't Google Services!-screenshot_2013-07-29-18-49-37.jpg
    07-29-2013 01:51 PM
  4. Crinny's Avatar
    Some one must have seen this before right?
    07-29-2013 05:33 PM
  5. AshManMB's Avatar
    No issues here. You should check one of the battery apps to see what could be causing your issue. .
    I charged mine for about 20 minutes in the morning while I was getting ready for work. Just posted to show you my Android services is low
    Sent from my SGH-M919 using Tapatalk 4 Beta
    Attached Thumbnails Battery drain that isn't Google Services!-uploadfromtaptalk1375155957831.jpg
    07-29-2013 11:46 PM
  6. ddemlong's Avatar
    The android OS battery drain started after the Play market updated to the 4.1.6. Its a known bug, its a problem with location services. download the 4,1.10 store and it fixes this bug, After I got the update my Android OS battery drain was 70-75% and only lasting like 12 hours. I updated the play store by downloading the .apk and now its back down to like 10%.
    07-30-2013 03:07 AM
  1. Replies: 9
    Last Post: 03-05-2015, 10:23 PM
  2. help! horrible battery drain on international s3
    By Chandnit in forum Samsung Galaxy SIII I9300
    Last Post: 08-01-2013, 01:23 AM
  3. Nexus 4 to Google Drive
    By obamabeard in forum General Help and How To
    Last Post: 07-31-2013, 07:49 AM
  4. Google+ Auto Awesome and 4.2
    By Mike Watling in forum HTC One M7
    Last Post: 07-29-2013, 06:09 AM
  5. Is this normal battery life for a galaxy s3?
    By Nathan Bullen in forum Samsung Galaxy SIII I9300
    Last Post: 07-29-2013, 04:21 AM
