I have been using battery guru for awhile but I saw people talking about juice defender and I wanted to know which one you like the best?
I have used Juice Defender and still use it on one of my own tablets.
I would actually not recommend either. Essentially, they both causes problems and their main tool for increasing battery life is shutting down stuff.
I have found that adding various battery saving utilities ultimately doesn't save me much and is not worth the trouble.
Android does a good job of managing power, let it work.
Have tried both more bad then good,what good is a phone if the radios get turned off,just turn the phone off if you want to save battery life.would not recommend either.
I leave the cell radio on to receive calls and texts. It makes perfect sense to turn off Wi-Fi and 3G if they are not being used for hours at a time if you gain increased battery life as a result of that action. It's not a problem for me to tap the notification shade and tap a toggle. I paid for Juice Defender Pro, so if it worked adequately for me, it would make sense to use it; since it doesn't, I don't.
Sent via Note II
